Flatback 22-2 Rebuilds
1968 22-2 FB rebuild
36
Topic: 1968 22-2 FB rebuild (Read 35392 times)
February 12, 2016, 05:30:21 PM
Reply #510
Re: 1968 22-2 FB rebuild
Reply #510 on:
February 12, 2016, 05:30:21 PM »
picked the boat up from the canvas shop today after having a custom eisenglass enclosure made will stay nice and dry/warm this time of the year
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
February 12, 2016, 08:30:57 PM
Reply #511
Reply #511 on:
February 12, 2016, 08:30:57 PM »
Looks great Aaron - you're really going to like it
February 15, 2016, 08:52:48 PM
Reply #512
Reply #512 on:
February 15, 2016, 08:52:48 PM »
pulled the 225 today and hung the 150 4s.
cleaned and repainted the midsection and tilt/trim bracket. should get the cowling and chaps back from paint later this week, and i sent the lower unit out for repair (bent propshaft, and broken skeg).
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
February 16, 2016, 10:07:28 AM
Reply #513
merkin222
Reply #513 on:
February 16, 2016, 10:07:28 AM »
Nice work, Aaron. Sounds like this is gonna be a real nice addition.
Have fish? Will travel.
February 16, 2016, 07:51:11 PM
Reply #514
dirtwheelsfl
Reply #514 on:
February 16, 2016, 07:51:11 PM »
What prop you thinking??
February 16, 2016, 08:23:44 PM
Reply #515
Reply #515 on:
February 16, 2016, 08:23:44 PM »
gonna try a 17p enertia eco. its the prop capt matt is running on his boat with this motor. getting over 5mpg
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
March 01, 2016, 09:28:32 AM
Reply #516
Reply #516 on:
March 01, 2016, 09:28:32 AM »
Hey Aaron, question for you. Did you put brakes on your trailer? I think you told me that you bought it without brakes, and I don't see an actuator on the tongue in your recent pics. Are you planning to add brakes? The reason I ask is that I sent Owen and Sons an email last night as I may buy a trailer this spring. I'm looking at the options including brakes. Not sure if I should buy it with brakes, or if adding them later would be a better option. Just wondering if that was the thought process you went through. Thanks!
And any updates on the new engine?
March 01, 2016, 12:09:14 PM
Reply #517
Reply #517 on:
March 01, 2016, 12:09:14 PM »
i opted not to get brakes, nor do i plan to add brakes. as most of my towing is short local trips(sometimes a couple times a week) and at times the trailer will sit for months when i keep the boat in a slip. i did not want the headache of one more thing to maintain, and jeff owens agreed. the only trailer of mine that i have ever had brakes on is my 15,000 lb triple axle. and even its brakes where questionable at best... i need to swing by owens, havent been by their shop since i picked up my trailer.
also one thing i will recommend is before the first launch with a new trailer, do 2 coats of sharkhide coating. the stuff really works. i did 2 coats when i first got the trailer and it still looks like new, zero corrosion or oxidization on the frame or fenders. im almost due for another coat.
nothing new on the engine. i did install a smartcraft harness, and gateway module so the motor can talk to the NMEA2000 network. thats about it. lower unit came back from the welder after having the propshaft straightened, a new skeg put on, and a crack found on the torpedo welded. just waiting on a seal kit to show up so it can get reassembled... still havent got the cowling and chaps back from fiberglass/paint.
my decals i ordered to match the boat came in., the OE decals have some red pin striping, i opted for the solid gray/silver
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
March 01, 2016, 01:11:29 PM
Reply #518
Reply #518 on:
March 01, 2016, 01:11:29 PM »
Thanks Aaron! I hadn't really thought of no brakes as an option, but it does make sense. I have brakes on the trailer for my Osprey, but they haven't worked for years. I usually only pull the boat out once or twice a year for cleaning and routine maintenance (it is lift kept), and I am only 2 blocks from the ramp. So the trailer does a lot of sitting. Is there a weight requirement where brakes are required? I do hope to travel more with the flat back, but it will not be a very common occurrence.
March 01, 2016, 01:56:02 PM
Reply #519
Reply #519 on:
March 01, 2016, 01:56:02 PM »
anything over i believe 3000 lbs is supposed to have brakes on all axles. the only area that really checks is down in the keys. ive never had an issue with it. most of my traveling with the boat is in N.FL, where im more likely to get checked for dyed fuel in my truck than brakes on the trailer.
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
March 01, 2016, 03:38:15 PM
Reply #520
flatbackpaul
Reply #520 on:
March 01, 2016, 03:38:15 PM »
is your Merc a 25" shaft?
March 01, 2016, 05:29:52 PM
Reply #521
Reply #521 on:
March 01, 2016, 05:29:52 PM »
yup
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
March 05, 2016, 09:27:27 PM
Reply #522
Reply #522 on:
March 05, 2016, 09:27:27 PM »
finally got the cowling and chaps back from paint/fiberglass repair, was able to finally rig the motor.
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
March 06, 2016, 07:02:34 AM
Reply #523
Reply #523 on:
March 06, 2016, 07:02:34 AM »
Lookin good Aaron.
March 06, 2016, 07:10:05 PM
Reply #524
Reply #524 on:
March 06, 2016, 07:10:05 PM »
installed new decals this afternoon
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
36
