Author Topic: 1968 22-2 FB rebuild  (Read 35391 times)
October 15, 2012, 10:03:55 AM
Read 35391 times
« on: October 15, 2012, 10:03:55 AM »
just started work on the flattie, removed the bracing that john built when he flipped the hull to sand the bottom. starting to cut out the middle stringer and grind out any damaged spots... will post pics later  :mrgreen:
October 15, 2012, 06:42:02 PM
Capt Matt
Re: 1968 22-2 FB rebuild
« Reply #1 on: October 15, 2012, 06:42:02 PM »
The joy of 5 stringers wide and 40 yr old bedding putty
looking for some more pictures
Capt Matt
Light tackle sportfishing
October 15, 2012, 08:25:22 PM
« Reply #2 on: October 15, 2012, 08:25:22 PM »
so, today, i dug into the flattie. got all of the foam out of the middle stringer, cut a large chunk of the stinger out, and cut almost all the foam out of the port stinger... all the foam pulled out pretty easily. <!-- s:cheers: -->:cheers:<!-- s:cheers: -->
water was dripping out of this one without even squeezing the foam... SOAKED!
this chunk had to weigh at least 70 lbs
October 15, 2012, 08:38:55 PM
dirtwheelsfl
« Reply #3 on: October 15, 2012, 08:38:55 PM »
I pulled around 1200# out of mine. That included the liner and decks though. How well are the stringers attached?
Getcha a bigger fan too!!
October 15, 2012, 08:43:07 PM
« Reply #4 on: October 15, 2012, 08:43:07 PM »
the stringers are in better shape than i originally thought. couple spots are cracked from the demolition, but should glass back pretty easily, theres almost no delamination... the fan is mostly used to suck the grinding dust away when i use the angle grinder. works pretty good.
October 15, 2012, 09:25:25 PM
« Reply #5 on: October 15, 2012, 09:25:25 PM »
Alright Aaron!!  Know you're having fun... :lol:  :lol:  :lol:
October 16, 2012, 01:37:09 PM
« Reply #6 on: October 16, 2012, 01:37:09 PM »
got 99% of the foam out, pulled out in large chunks pretty easy, also cut the 2 outer stringers so additional glass can be added along the chines. the port stringer is in excellent condition, and the middle stringer is on pretty good condition also, the starboard stinger has some rough spots where the bonding putty broke loose when the deck was being ripped out, nothing a little glass wont fix.
pics will come later, time to go get some FOOD :cheers:
October 16, 2012, 06:43:40 PM
« Reply #7 on: October 16, 2012, 06:43:40 PM »
heres some more pics!
filled the back of the truck, one bag of foam didnt make it
how she's currently sitting
October 16, 2012, 06:53:38 PM
« Reply #8 on: October 16, 2012, 06:53:38 PM »
Excellent Aaron!   :thumleft:
October 16, 2012, 08:30:25 PM
dirtwheelsfl
« Reply #9 on: October 16, 2012, 08:30:25 PM »
Stringers look well bonded. Getting rid of the liner?
October 22, 2012, 10:48:53 AM
« Reply #10 on: October 22, 2012, 10:48:53 AM »
Quote from: "dirtwheelsfl"
the port and middle stringer and the port side of the starbord stringer are in great shape, and rock solid, the starboard side of the stringer got damaged when the deck was ripped out, will glass it back down inside and out, and add additional glass to the whole inside of the boat.
scott, this one is for you, she has a glassed cap
October 22, 2012, 11:05:02 AM
dburr
« Reply #11 on: October 22, 2012, 11:05:02 AM »
Any time a gas powered leaf blower is involved in demo is a GOOD time  :mrgreen: !  Just bumming that an 8 foot Johnson bar wasn't in the picture too... :shock:  :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
October 22, 2012, 11:40:01 AM
« Reply #12 on: October 22, 2012, 11:40:01 AM »
Quote from: "dburr"
if the boat was at work, there probably would have been lol
meeting with a sandblaster on Wednesday or thursday at my work for an estimate, anyone know any sandblasters in pinellas?
October 22, 2012, 11:46:29 AM
« Reply #13 on: October 22, 2012, 11:46:29 AM »
Quote from: "Aswaff400"
Sweet!!
You're really gonna enjoy this boat :thumright:
October 22, 2012, 11:48:39 AM
wessnapp
« Reply #14 on: October 22, 2012, 11:48:39 AM »
A high school classmate owns Bayside Sandblasting.  If you call that company, tell Keith Begin I said hello.
I drove by earlier today to see if you were working....I'll try stopping by later.
St. Petersburg, Florida
