Author Topic: Classic proline 20 rebuild  (Read 4425 times)
October 13, 2012, 11:04:14 PM
Read 4425 times
backdraft1887
« on: October 13, 2012, 11:04:14 PM »
Hello everyone my name is evan and i recently bought a old flatback proline. I statrted the process of cutting the liner and floor out. and she sits on a cradle i bulit for the overhall. My plans are a half tower with enclosed transom and porta bracket. Ive lurked on her for a long time and finally decided to get my hand dirty. Look forward to any advise along the way!
Heres her new home for a while...
October 14, 2012, 08:05:53 AM
Deck Daddy
Re: Classic proline 20 rebuild
« Reply #1 on: October 14, 2012, 08:05:53 AM »
I like the cradle. Building the same thing for my rebuild to work on her in the garage this winter. Good luck with the build, those 20's have nice lines.
One boat at a time.
October 14, 2012, 06:34:52 PM
« Reply #2 on: October 14, 2012, 06:34:52 PM »
If you do the rebuild anything like the cradle, it'll be a stout boat. :thumleft:
October 15, 2012, 10:58:21 AM
backdraft1887
« Reply #3 on: October 15, 2012, 10:58:21 AM »
Here are some more pics
This is after i cut the liner out, looks like someone had reglassed the front part of the floor once
Heres the beginning of gutting her
October 16, 2012, 08:22:19 PM
backdraft1887
« Reply #4 on: October 16, 2012, 08:22:19 PM »
Got the rest of the floor out and most of the foam. I went to lift the cap from the transom and the other owner had glassed it to the hull. should i just cut it off with a cut off wheel?
October 16, 2012, 09:01:56 PM
dirtwheelsfl
« Reply #5 on: October 16, 2012, 09:01:56 PM »
Yes, ideally youd be able to cut down to the outside skin and pry it up and off, depending on how well they glued it (or not).  Probably easier to cut across the cap about where that orange screwdriver is though. Then glass it back later...
October 16, 2012, 09:20:01 PM
backdraft1887
« Reply #6 on: October 16, 2012, 09:20:01 PM »
After further insepction it looks like the just put a layer of 6oz on the out side, hopefully tomarrow i can get it off
October 16, 2012, 10:31:21 PM
« Reply #7 on: October 16, 2012, 10:31:21 PM »
Quote from: "backdraft1887"
Cut off wheel or die grinder will take care of that in a heartbeat...
October 17, 2012, 05:33:05 PM
melba toast
« Reply #8 on: October 17, 2012, 05:33:05 PM »
Look forward to seeing what you do. I'm seeing a lot of familiar things so far... I like the cradle !
October 17, 2012, 09:27:47 PM
backdraft1887
« Reply #9 on: October 17, 2012, 09:27:47 PM »
Ive read through ur build atleast 10 times hahaha
October 17, 2012, 09:58:14 PM
« Reply #10 on: October 17, 2012, 09:58:14 PM »
Like how you're starting off...I'm with Melba and the boys :wink:
October 18, 2012, 07:22:29 PM
backdraft1887
« Reply #11 on: October 18, 2012, 07:22:29 PM »
Got the rest of the foam and started the dreadful process of cleaning 40+ years of dirt and rotten wood out of her. Im trying to get it pretty clean before i sand blast the inside of the hull.
October 18, 2012, 07:48:49 PM
« Reply #12 on: October 18, 2012, 07:48:49 PM »
You guys ever notice the incredible difference between AS stringers and PL stringers of the same vintage?
October 18, 2012, 08:26:25 PM
backdraft1887
« Reply #13 on: October 18, 2012, 08:26:25 PM »
Yeah the only thing left of the proline stringers are the few tabs of glass and a bunch of dirt dobber nest, a rat was living in them too lol
October 18, 2012, 08:38:08 PM
« Reply #14 on: October 18, 2012, 08:38:08 PM »
Evan,
Where you at in Wesley Chapel?  Get down 41 a lot heading either down Florida Ave or picking up Dale Mabrey S of 54...
