Author Topic: Got her in the water today...  (Read 493 times)
October 11, 2012, 02:54:36 PM
Read 493 times
stanggt
« on: October 11, 2012, 02:54:36 PM »
Well after a month or so of working on her, I finally took her out today for a test run.  All went well except it would not trim (up or down).  I believe its low on fluid.  The water pump I installed is working fine.  I had 10-20 lbs pressure on the gauge the whole time under throttle.  I made a few high speed runs, putted around for a while and then called it a day.  Next time out I will be testing all pumps/lights/trolling motor.  All in all I had fun even though I called it quits after and hour and a half.
