Author Topic: First time boat owner / boat launching question(s) -  (Read 888 times)
October 08, 2012, 12:05:13 PM
kraw2
Re: First time boat owner / boat launching question(s) -
« Reply #15 on: October 08, 2012, 12:05:13 PM »
If the ramp you are using has finger piers on each side to help with moving boats around this is what I used to do.
Do everything already mentioned.
Back the boat down while the other person is holding the bow and stern ropes. It only takes one person. Back down and bump the brakes to let the boat ease off the trailer by itself while the person on the dock holds both ropes. Go park the truck and trailer. The other person will have you ready to go. Get in the boat and go...
October 08, 2012, 12:57:45 PM
« Reply #16 on: October 08, 2012, 12:57:45 PM »
Ditto on what Kraw said.  I do everything already mentioned.  When I unstrap the stern of the boat I put in the plug and give the primer bulb a couple of squeezes. My "first mate" and crew hold the bow and stern lines.  I back the trailer down the ramp stopping when the stern of the boat is above or touching the water a bit.  I set my parking brake, get out, unhook the bow safety chain and winch strap.  I do not unhook the bow from the trailer before I back down the ramp so the boat does not slide off the trailer on to the concrete!  Then I slowly back down the ramp and tap the brakes.  The boat slides right off and I head for a sparking spot.  My crew ties the boat to the dock and starts the engine... so by the time I get back to the boat she is running and ready to go.
October 08, 2012, 02:01:26 PM
« Reply #17 on: October 08, 2012, 02:01:26 PM »
Quote from: "wingtime"
