Author Topic: Barnacle husk removal  (Read 1414 times)
September 26, 2012, 10:15:38 AM
Read 1414 times
foreverstrung
« on: September 26, 2012, 10:15:38 AM »
I would be open to any thoughts about cleaning barnacle husks off my hull. I had my son in law scrap about 40% of them off last weekend with a putty knife and small amounts of "on and off". It worked well, just took forever. The pros say it needs to be sanded. If I do that, will I most likely have to re apply gelcoat? Or can I sand it ever so lightly, just at the husks and wax?
2000 Aquasport 215 Explorer/Mercury 200, carb 2 stroke
September 26, 2012, 10:17:54 AM
foreverstrung
Re: Barnacle husk removal
« Reply #1 on: September 26, 2012, 10:17:54 AM »
I'll post a pic later today. It's got about 3 and a half months of growth. Power washed and scraped upon removel from the water. Just the husks now.
I'll never leave it in the water again that long. I want to get it lookin nice and I'll keep her on the trailer
September 26, 2012, 10:46:08 AM
« Reply #2 on: September 26, 2012, 10:46:08 AM »
http://www.youtube.com/watch?v=kNOi2pQLQcI
pay attention to the last part of this video...I believe the same result could be acheived using a multi type tool with a scraper blade attachment
http://www.harborfreight.com/power-tool ... 68861.html
http://www.harborfreight.com/catalog/pr ... egory/688/
good luck! :salut:
September 26, 2012, 10:58:07 AM
Georgie
« Reply #3 on: September 26, 2012, 10:58:07 AM »
I didn't see it mentioned, so I'd imagine the first question is, "Does the boat have anti-fouling paint?"  If so, you might be able to get underneath the antifouling layer and remove the barnacles and paint without sanding...either with the help of chemical removers or more precision scrapers.  If not, sanding/buffing back to a quality finish might be possible without the need to re-gel the bottom if you're careful not to sand all the way through the existing gelcoat layer.  It'd probably be a painstaking labor O love though.  Otherwise, the "pro's" you've already talked to are probably right.  Others here who have done more of this work will have better feedback though.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
September 26, 2012, 11:19:43 AM
dburr
« Reply #4 on: September 26, 2012, 11:19:43 AM »
Quote from: "pete"
 :salut:
Boy I would have loved to have that in a previous life.  Old school was a clorox bath followed by a hard sharp scraper, then with a light hammer and sharp chisel for what was left...
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
September 26, 2012, 12:33:36 PM
foreverstrung
« Reply #5 on: September 26, 2012, 12:33:36 PM »
Nice feedback guys. I've got one of these tools. Made by Dremel. I had one of those blades, if i can't find it I can pick one up at Home depot. I'll let you know how it goes.
     And no, there is no fouling paint
September 26, 2012, 09:39:56 PM
HIFLUTIN
« Reply #6 on: September 26, 2012, 09:39:56 PM »
Leave it out of the water for a week or 2 they will flick off easier
September 27, 2012, 08:03:11 AM
« Reply #7 on: September 27, 2012, 08:03:11 AM »
Let them dry and soda blast...
September 29, 2012, 06:47:25 AM
foreverstrung
« Reply #8 on: September 29, 2012, 06:47:25 AM »
What do you mean, "soda blast", John? The dremel tool didn't vibrate the husks loose like in the video. It scraped them, but it'll take forever and a year to get each one that way and it still leaves discoloration which I hit with the "On and Off", gel,but did little good. I think I may have to sand some of this discoloration off. Thunderstorms right now, so I won't be able to get back under the trailer till Sunday at best
September 29, 2012, 09:10:08 AM
« Reply #9 on: September 29, 2012, 09:10:08 AM »
Quote from: "foreverstrung"
http://www.youtube.com/watch?v=mJguD-rbbIU
September 30, 2012, 09:02:01 PM
foreverstrung
« Reply #10 on: September 30, 2012, 09:02:01 PM »
Ya, I did some research on this. Watched a few videos. There's got a 15 gallon model That I can run off my compressor that sells for about $100 at harbor freight. But will it take those husks off? Even after they dry? All the videos I watched, I didn't see any husk removal. Just algae
October 02, 2012, 01:49:57 PM
« Reply #11 on: October 02, 2012, 01:49:57 PM »
I only watched the video of the "wave tool", but I don't think you would get the same results on your boat, either with this tool or your dremel, if you do not have bottom paint.  The barnacles will adhere to the bare bottom much better than to bottom paint, even if the paint is rather old.
