Author Topic: NEED WIRING DIAGRAM  (Read 978 times)
September 24, 2012, 10:34:44 AM
Read 978 times
nobannans
NEED WIRING DIAGRAM
« on: September 24, 2012, 10:34:44 AM »
:? Having trouble with battery sw.Am in need of a wiring diagram for 2001 Aquasport275 exployer.
2 switches an 3 batteries.THANKS DOUG     dkonowal@roadrunner.com
September 24, 2012, 10:52:14 AM
Re: NEED WIRING DIAGRAM
« Reply #1 on: September 24, 2012, 10:52:14 AM »
Moved this topic because it's definitely not a "Web Site Issue.
Here's a link to get you started on the basics.
http://classicaquasport.com/smf/index.php?topic=9053.msg79505#msg79505
At one time, there were diagrams on the Wellcraft site for the last Aquas produced.
Some members may have one.
http://classicaquasport.com/smf/index.php?topic=7552.0
Google may be your friend.
<!-- m -->http://www.boatfix.com/how/Ele2.html<!-- m -->
Introductions are welcomed and greatly appreciated but not all give them when asking for help right out of the box.
I'm just sayin.
September 24, 2012, 12:21:41 PM
« Reply #2 on: September 24, 2012, 12:21:41 PM »
Well good afternoon Doug, nice to meet you too!  :mrgreen:
CB, good link to the boatfix page, but a small problem with their diagram for a twin engine boat with a third house batt.  The good majority of builders, Aquasport included, have a selector switch (OFF/1/ALL/2) for each stating batt.  That precludes putting the house batt on the same switch as either one of the start batts...
Soooo, Doug could have 1 of 2 setups, seeing as he has only 2 switches.  The first may be that one start batt is wired in parallel with the house batt to create a large house/start bank, still 12V but double the amp hours.  The second may be that the house batt is connected to an isolator, VSR, ACR, or the like, whereas the house batt is brought into the charging loop when the motors are running, then isolated when they are shut down.
John (Double Trouble) just re-did his cabling a couple years ago on his 275.  Can't remember how he did it (think he used a Blue Seas ACR), be good for him to chime in here...
September 24, 2012, 01:16:03 PM
Double Trouble
  • NorthEast
« Reply #3 on: September 24, 2012, 01:16:03 PM »
I cant find the diagram but I will keep looking. I know I used a BEP switch with a VSR when I put the switch on #1 my house battery is isolated when I switch it to #2 the house battery gets charged off the engines. Here ius a link to the switch I used. http://www.bepmarine.com/Single-Engine, ... ml#details
September 24, 2012, 01:28:20 PM
« Reply #4 on: September 24, 2012, 01:28:20 PM »
Quote from: "Double Trouble"
Told ya I couldn't remember, John... :shock:  :shock:
September 24, 2012, 01:32:11 PM
Double Trouble
  • NorthEast
« Reply #5 on: September 24, 2012, 01:32:11 PM »
My mind is a wonderful asset if I can only remember where I put it.
September 25, 2012, 05:12:46 AM
Double Trouble
  • NorthEast
« Reply #6 on: September 25, 2012, 05:12:46 AM »
I found it.
