Author Topic: Twin F115's on a 1995 245 explorer?  (Read 1541 times)
September 21, 2012, 08:00:39 AM
Read 1541 times
StinkyStu
« on: September 21, 2012, 08:00:39 AM »
I have my eye on a 1995 245 explorer w/o engines, and I have a pair of 2006 Yamaha F115's sitting on my old boat with a cracked transom.  Anyone know if these motors would push this boat, and what kind of numbers I would be looking at?  I am not looking to be a speed demon because I have an ageing father who has a hard time with the typical 3-4' chop in my area.  Fuel consumption is my main interest.  My old boat is a 1990 23' Bayliner Trophy that weighs 280 lbs less than the 245 explorer, and I was getting about 2.3 mpg at 20 mph cruise.  Any help would be appreciated.
Thanks,
Stu
September 21, 2012, 08:42:02 AM
Re: Twin F115's on a 1995 245 explorer?
« Reply #1 on: September 21, 2012, 08:42:02 AM »
They will do a fine job for you.
A friend has a pair of 115 2 stroke yammies on a 250 CCP. He gets 40 mph WOT, 2.1 mpg @ 4200 rpm.
The 4 strokes will do better in terms of mpg.
All you need in terms of power, with the reliability/maneuverability of twins.
Nice ride!
September 21, 2012, 10:06:21 AM
« Reply #2 on: September 21, 2012, 10:06:21 AM »
A pair of F115s would be a great choice for a 245.  Not too little, not too much - just about right IMHO...
September 21, 2012, 11:55:41 AM
« Reply #3 on: September 21, 2012, 11:55:41 AM »
Those should push it along OK  I have a single 225 two stroke on my 245 Explorer and I can cruise at 28-30 mph burning about 15 gph.  Wide open with a light load she will do 40 mph.  And thats with a hard top and bottom paint.  I don't think a single 115 will get you up on plane but it will get you back into port.  Also you could troll on one engine pretty good too.
September 21, 2012, 12:17:15 PM
« Reply #4 on: September 21, 2012, 12:17:15 PM »
Bruce, wonder what the dry hull weight of your hull is?
Reason I ask...if it is under 3200, a single MIGHT plane her....
September 21, 2012, 12:22:51 PM
StinkyStu
« Reply #5 on: September 21, 2012, 12:22:51 PM »
NADA says that the 1995 is 3400 lbs dry.  I could almost get my trophy on a plane with the trim tabs on one engine, and it was 3120 lbs dry.
September 21, 2012, 12:52:15 PM
« Reply #6 on: September 21, 2012, 12:52:15 PM »
95 Aqua catalog lists it at 3800# dry. Maybe that's with single outboard.
94 cat. lists @ 3400#
September 21, 2012, 01:17:25 PM
« Reply #7 on: September 21, 2012, 01:17:25 PM »
Me thinks those dry weights are a tad low.  My 245 on the trailer weighs in at 6K.
September 21, 2012, 02:52:15 PM
« Reply #8 on: September 21, 2012, 02:52:15 PM »
Gotcha. Then a single 115 won't plane her.
She should get in the upper 30's though @WOT, and cruise @ 4200 around 28-29 mph.
Bruce, that sound about right?
September 21, 2012, 03:23:31 PM
« Reply #9 on: September 21, 2012, 03:23:31 PM »
yeah Thats It Scott. I cruise at 4200 RPMs which gives me 28-20 mph depending on load seas etc.  WOT is 38-40mph.  I cruise based on my Flowscan gauge.  I try to keep it around 14-15 GPH
September 23, 2012, 09:31:45 PM
« Reply #10 on: September 23, 2012, 09:31:45 PM »
By those numbers i find it hard to believe our boats with cabins made out of wood only weight 200lb more then an Osprey.
September 23, 2012, 09:59:09 PM
« Reply #11 on: September 23, 2012, 09:59:09 PM »
Quote from: "Circle Hooked"
Guaranty you that!  Between the glass and coring, the cabin berth, galley, windshield...WAY more than 200 lbs.!  An Osprey console weighed around 100, I would guess.  Maybe 125.  When I dropped it in the boat, it was easy to move around to center it, the last tweaks with just a good tap with my foot, side to side...
September 23, 2012, 10:09:46 PM
« Reply #12 on: September 23, 2012, 10:09:46 PM »
Heck I bet my windshield alone weighs more then 50lb with the glass
September 23, 2012, 11:10:20 PM
« Reply #13 on: September 23, 2012, 11:10:20 PM »
Yep.  Now, although you don't have one, Scott, compare a t-top with a hardtop.  Big difference there...
But back to the 115s.  Way back in the 90s, Boating magazine, when it was still a magazine, did a boat test on a 225 Osprey with twin 115s.  Performance was...OK.  Damn I wish I could find that article.  But on a 245, later the 250?  She's actually closer to 26" in LOA.  I don't know.  Granted her standard motor IIRC was a 200, may have been a 225, but most opted for a 250 Yam or twin 150s...
What I'm saying is better to have more power than you need, than wish you had more power than you have.
September 23, 2012, 11:16:24 PM
« Reply #14 on: September 23, 2012, 11:16:24 PM »
But with the slanted windshield we have less drag when under way :D
