Author Topic: Transom Bait Box Drain?  (Read 509 times)
September 19, 2012, 03:05:48 PM
Read 509 times
kraw2
« on: September 19, 2012, 03:05:48 PM »
For those of you that use the transom bait box's how did you install a drain? I have the high speed pickup with and adjustable flow head and the overflow fittings up top. Not installed in this picture.
September 19, 2012, 03:25:07 PM
Re: Transom Bait Box Drain?
« Reply #1 on: September 19, 2012, 03:25:07 PM »
You got a gorgeous job :thumright:
Eugene at Shipoke recommends a basic transom plug at the inboard corner of each at the transom.
Open the top, lean over the transom, and pull the plug.
September 19, 2012, 04:41:37 PM
kraw2
« Reply #2 on: September 19, 2012, 04:41:37 PM »
I'm assuming the drain would be in the bottom..!
I will probably grind the drain housing down so it will not protrude into the water. Or would it matter if the housing is dragging..??
September 19, 2012, 04:50:09 PM
kraw2
« Reply #3 on: September 19, 2012, 04:50:09 PM »
In the bottom, aft of the pickup, I drilled a small hole. That's where I'll put the garboard drain. It will be in the "draft" of the pickup and probably won't matter if it sticks out.
September 19, 2012, 04:59:13 PM
« Reply #4 on: September 19, 2012, 04:59:13 PM »
He was saying thru the side, in the lower corner, directly above where the shadow of your camera appears.
September 19, 2012, 07:29:21 PM
kraw2
« Reply #5 on: September 19, 2012, 07:29:21 PM »
Thanks Scott,
I was thinking on the side also. I would put it on the inboard side so it doesn't break up the clean look.
September 19, 2012, 07:42:55 PM
« Reply #6 on: September 19, 2012, 07:42:55 PM »
Just saw the boat pics, man, she looks GREAT!
Another idea on the box drains....Fitz came up with this, and it works great:
At the back inboard corner, but going straight out the back....install 2 ball scuppers.
(edit: right above where that dead fly sits back there :lol: )
When you want to use them for bait, just plug the scuppers from the inside.
Otherwise, you can use the boxes for storage, and they never hold water, except for a little rainwater.
Any water that gets in...when you throw her on plane...runs straight out the back, boxes becomes totally dry :thumright:
