Author Topic: No Fresh water pressure  (Read 645 times)
September 07, 2012, 01:29:55 PM
Read 645 times
Mark Redmon
« on: September 07, 2012, 01:29:55 PM »
I don't have freshwater pressure anymore.  I assume it's the pump or pressure switch.  Can someone tell me where the pump is located on a 2005 275 Explorer?
Thanks,
Mark
Melbourne FL
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
September 07, 2012, 10:14:19 PM
Re: No Fresh water pressure
« Reply #1 on: September 07, 2012, 10:14:19 PM »
Mark,
PM Double Trouble,he has a similiar boat.
Pump on mine is near the water tank,find the tank and follow the lines if you can,good luck :salut:
September 07, 2012, 11:12:00 PM
« Reply #2 on: September 07, 2012, 11:12:00 PM »
Mine is in the transom just under the transom door.
September 08, 2012, 05:47:41 PM
skyliner4444
« Reply #3 on: September 08, 2012, 05:47:41 PM »
Sometimes just reseating the compression fittings/hoses can fix the problem. If any have loosened, the pump starts sucking air instead of water from the tank.
September 08, 2012, 10:26:23 PM
« Reply #4 on: September 08, 2012, 10:26:23 PM »
If the pump runs, but you have no flow, then it would be sucking air BIG TIME!  But those lines just don't simply pull out by themselves...
If the pump was running, you could trace down it's location by following the noise.  So it sounds like the pump isn't running.  Check voltage on the back side of the switch in the on position.  Determine voltage or no voltage.  Should you have voltage, and the breaker doesn't trip, sounds like a stuck float in the pressure switch on the bottom side of the pump motor housing.
Now it's just a matter of finding the pump!!
September 09, 2012, 01:46:35 PM
Double Trouble
  • NorthEast
« Reply #5 on: September 09, 2012, 01:46:35 PM »
Mark
  The pump is under the hatch in the aft cabin on the bulkhead behind the fresh water tank.
