Engines & engine woes
Sunk twin Yam 200s
Topic: Sunk twin Yam 200s (Read 2300 times)
September 04, 2012, 07:37:24 PM
Read 2300 times
mevince
Sunk twin Yam 200s
September 04, 2012, 07:37:24 PM »
Im looking at a Grady White that sunk overnight in saltwater. Only the motors and back half went under. Was removed the following morning and washed down. The motors had the oil changed and manually turned over. Was told the wiring harnesses needed replaced. The seller prob got insurance check and dont care now cause he said he didnt want to mess with it now. What are the chances these motors are still good? They are 2001 Yamaha V6 Saltwater Series 2. I can get the whole package for $2000. Is it worth it and can the motors be salvaged?
September 04, 2012, 07:38:34 PM
mevince
Re: Sunk twin Yam 200s
September 04, 2012, 07:38:34 PM »
Grady is a 1985 25'
September 04, 2012, 08:02:49 PM
September 04, 2012, 08:02:49 PM »
The trailer alone is worth $2000, as far as the motors go if they were under water they should have been pickled immediately. If not internal corrosion may be an issue. The boat and trailer are well worth the asking price. There is a set of 200 Yamahas for sell right here on the site.
September 04, 2012, 08:11:10 PM
Purgatory
September 04, 2012, 08:11:10 PM »
Here they are. If Bob says they're good, they're good:
viewtopic.php?f=6&t=9626
September 04, 2012, 11:02:01 PM
Mechanical Master
September 04, 2012, 11:02:01 PM »
Salt water is hard on electronics, but sometimes you get lucky. I've seen a motor get submerged, pulled out quickly, washed off, plugs pulled, cleared out, and then ran fine. BUT - I think that was highly unusual. How long was it under water - a full overnight means salt water got to places where it should not go - like injectors and/or carb bushings.
So consider the others advice and maybe get the boat with the intention of throwing the motors away or selling them to a rebuider - but maybe invest a couple hundred $$ and - just maybe - you may find the motors are OK and you've really stolen that boat!
September 05, 2012, 10:36:11 AM
kraw2
September 05, 2012, 10:36:11 AM »
Buy It..!!
September 05, 2012, 06:44:07 PM
mevince
September 05, 2012, 06:44:07 PM »
Going to get the Grady tomorrow in Rock Hill. 2hrs one way. Meeting Scott sunday to deliver 22-2. 3hrs one way. Need to sell a 1978 SeaCraft Master Angler Potter Hull that I picked up 2 wks ago in Tenn. 4hrs one way. The things we do for water toys!
September 05, 2012, 07:08:10 PM
kraw2
September 05, 2012, 07:08:10 PM »
Man you have been busy. I wish you weren't so far away. I would tank one off your hands...
September 05, 2012, 07:18:18 PM
Purgatory
September 05, 2012, 07:18:18 PM »
Somebody here needs to think about that Potter. They don't grow on trees
September 05, 2012, 08:51:22 PM
mevince
Reply #9 on:
September 05, 2012, 08:51:22 PM »
Kraw2 Ill meet you halfway for the right price. Obviously Im not worried about going far!
Its a good hull. Just too small for what Im going to be using it for or it would stay here. Needs the usual redone. Floor, transom, and cap. Hull has 4yr old gelcoat that has not seen the water. Center console. Seats. Tank that has been pressure tested. Aluminum Ibeam tandem axle trailer.
September 06, 2012, 01:00:23 AM
Reply #10 on:
September 06, 2012, 01:00:23 AM »
Scott, you building up a used boat lot?
An Aquasport Fleet.
September 06, 2012, 01:17:28 AM
Purgatory
Reply #11 on:
September 06, 2012, 01:17:28 AM »
Quote from: "RickK"
An Aquasport Fleet.
Say the word...never seen a boat that wasn't for sale
September 06, 2012, 01:38:18 AM
Purgatory
Reply #12 on:
September 06, 2012, 01:38:18 AM »
A seventies 20 Seacraft is smoking hot, and desirable.
Good looking too.
It rides like a knife through warm butter. "Nothing rides like a Seacraft" and that phrase, although a former marketing term, is the truth regarding the 20 Potter Seacraft.
The 20 runs FAST in a head sea. Not a small sea either. Three foot decent sea, the hull will happily run a solid 28 mph all day....and dry on the entry. You won't believe this old twenty foot hull will scald a 23 Contender in the open ocean. But it will.
September 06, 2012, 12:47:02 PM
Rigging Master
Reply #13 on:
September 06, 2012, 12:47:02 PM »
There IS a reason this site exists...
http://www.classicseacraft.com/
September 06, 2012, 07:34:36 PM
mevince
Reply #14 on:
September 06, 2012, 07:34:36 PM »
I dont like it over there Seabob4! Please dont make me go back :|
Sunk twin Yam 200s
