Author Topic: PVC Boat Guide  (Read 2303 times)
August 29, 2012, 09:11:44 AM
Read 2303 times
pigbike
PVC Boat Guide
« on: August 29, 2012, 09:11:44 AM »
I see many trailers with PVC pipe V guides for the bow.  Is there something inside the PVC to support the PVC, like galvanized pipe?
August 29, 2012, 09:14:17 AM
Re: PVC Boat Guide
« Reply #1 on: August 29, 2012, 09:14:17 AM »
Yep.  I've seen re-bar used...
September 26, 2012, 05:26:09 PM
Re: PVC Boat Guide
« Reply #2 on: September 26, 2012, 05:26:09 PM »
Skip the V and go with front bunks - works much mo' bedda!
September 26, 2012, 07:19:41 PM
Re: PVC Boat Guide
« Reply #3 on: September 26, 2012, 07:19:41 PM »
Quote from: "GoneFission"
yup
September 26, 2012, 08:20:33 PM
Re: PVC Boat Guide
« Reply #4 on: September 26, 2012, 08:20:33 PM »
I never had them before but here's mine.
Hard to see but the square pipe  is covered by the PVC.
This trailer, maybe due to blind luck, is so much easier to launch and retrieve. It's rare that I drive the WAC on so pulling it on needs to work with a minimum of effort for me. I'm thinking the V posts help a lot but probably more so the relation of the whole trailer ie bunks, roller and PVC V work to make it so.
September 28, 2012, 08:48:10 AM
pigbike
Re: PVC Boat Guide
« Reply #5 on: September 28, 2012, 08:48:10 AM »
Nice shine on your boat Capt. Bob
September 28, 2012, 09:27:24 AM
Re: PVC Boat Guide
« Reply #6 on: September 28, 2012, 09:27:24 AM »
Quote from: "pigbike"
Thanks. It's all in the wrist.   :mrgreen:
That stated, the real credit goes to our Public Relations Director.  :salut:
I just did what I was told, still....
For a 21 year old hull, it does clean up well.  8)
February 26, 2013, 09:42:55 AM
Bergertime
Re: PVC Boat Guide
« Reply #7 on: February 26, 2013, 09:42:55 AM »
I have the same piece on my trailer with v-bar covered by PVC pipe and pvc plate in the middle.  Has this caused any damage to the keel of your vessel?
I was concerned that it was damaging the gel-coat on the bottom of the keel of mine since there was some gel-coat damage (round chuncks missing)  that appeared to be repetitive in nature present when I purchased the boat.  Not sure of the cause since the PO had the boat in a high and dry and trailered very infrequently.
However, In the prior configuration or its new one my boat does not contact the plate when fully loaded on the trailer.  I just recently had the keel repaired and I lowered the whole unit down to the lowest position so that it would protect / prevent the boat from hitting the trailer cross member but would not come in contact otherwise.  It’s worthy to note I have 3 large bow rollers approx 3 feet back.
1)   Is this plate supposed to support the weight of the boat when fully loaded onto the trailer or used just a guide for launching or loading?
2)   Do I have it set up properly?
3)   Am I at risk  for the way I have it set up?
4)   Do you have any damage to the gel-coat from contact?
-Bruce
98 245 Osprey / Johnson 225
February 27, 2013, 08:43:11 AM
Re: PVC Boat Guide
« Reply #8 on: February 27, 2013, 08:43:11 AM »
Quote from: "Bergertime"
Bruce
On my boat, the bow is supported by a Stoltz roller. It is not supported by the PVC guide (I can fit my finger under it) but.....
There is visible scraping on the guide pad and I do have damage to my keel (gelcoat gone). I first thought is was from the PO's activity of beaching on a sandbar for family outings (Gulf boat). Now I can see that maybe this was caused or enhanced by pad contact. I usually have this pad with a fair amount of water between the the hull and the boat retrieves very easily. Still...
I'd think you'll be OK, just something one lives with trailering. Probably more so on launch than retrieve and increased with lousy ramps.
February 27, 2013, 06:56:23 PM
Re: PVC Boat Guide
« Reply #9 on: February 27, 2013, 06:56:23 PM »
I did away with mine years ago and built this, couldn't be happier and no scrapes
March 19, 2013, 12:11:33 PM
Bergertime
Re: PVC Boat Guide
« Reply #10 on: March 19, 2013, 12:11:33 PM »
Well I started to tackle my PVC guide issue and I found an easy fix thanks to the good guys at TA Mahoney's.  Stoltz makes a poly cap that covers the PVC plate at the bottom of the guide thus protecting your gel coat.  It is made to screw in via four mounting slats but since my PVC cap was too thick to mount that way I affixed it with some sturdy zip ties.   Here is a link to what I purchased.  Hope it helps..
http://www.easternmarine.com/4-x-12-sto ... d-pad-4112
-B
May 07, 2013, 11:28:54 AM
BStrailer
Re: PVC Boat Guide
« Reply #11 on: May 07, 2013, 11:28:54 AM »
Most of the time there is a galvanized pipe going threw the center of the Pvc
A lot of people go to front loading bunks instead of the pvc brackets
it makes it easier to load and protect the bottom of the boat better
but here is a link to the pvc bow guides
Cliff@ B&S Trailer
http://www.bstrailer.net/assets/images/ ... -Parts.pdf
May 07, 2013, 03:11:12 PM
Bergertime
Re: PVC Boat Guide
« Reply #12 on: May 07, 2013, 03:11:12 PM »
Thanks!  It was the keel pad that resolved the issue for me.
B
July 15, 2013, 03:58:23 PM
captianrich0418
Re: PVC Boat Guide
« Reply #13 on: July 15, 2013, 03:58:23 PM »
I had the same issue with my bow guide. The plastic plates wore out and damage to the gelcoat on my keel was the result. I tried to replace the pad with one like yours but I could not drill new holes in the metal and zip ties will not last. So I took the whole thing off and replaced it with a 8" keel roller.
http://www.trailerpartsdepot.com/itemde ... E54OPB&Tp=
I plan to fix the bow guid and sell it on craigslist.
Rich
My 215 Osprey Sport
