Author Topic: c115 Yamaha fuel issue  (Read 850 times)
August 24, 2012, 10:28:44 PM
mainefinn05
Re: c115 Yamaha fuel issue
« Reply #15 on: August 24, 2012, 10:28:44 PM »
Cheap inline and a racor seemed to have helped for now. I'll get to the tank this winter. Ran well, even pulling against the two filters. Much happier with cleaned out carbs and clean fuel.
August 25, 2012, 04:14:57 PM
saltfly
« Reply #16 on: August 25, 2012, 04:14:57 PM »
Capt. Bob is on the right track. The Ethanol is most likely causing your problem. It can be dissolved varnish. But was Oxygenated gas  used in the tank? If so, it has MPBE in that gas. Which leaves a coating on the inside of the tank. As you use it, the more it builds up. And as long as you continue to use it. It doesn’t  cause the problem, that sound like you are having. But once you switch to Ethanol. It dissolves the coating and it clogs carbs. and jets. It looks a lot like sand. The only way to get it out of your tank, is to have it steam cleaned or replace the tank.
