If your getting sags and your not laying it on real heavy you probably want to go down to a smaller tip size on the gun. It means that the thinner paint is coming out of your gun easier and your piling it on. Either change the tip or change your spraying technique to compensate. Try to spray in long runs if you can, that way you dont have vertical overlap blocks, you just have the horizontal lines that overlap over the length of the boat, like lapstrakes.
beautiful boat! Its been a while since i've been on this site but my boat that I built looks identical. Awe grip sea foam green, quality tower and a 175 suzuki 4 stroke.
Quote from: "wiler55"beautiful boat! Its been a while since i've been on this site but my boat that I built looks identical. Awe grip sea foam green, quality tower and a 175 suzuki 4 stroke.Why'd you stop posting pix?
