Flatback 22-2 Rebuilds
1971 Flatback
22
23
24
25
31
Topic: 1971 Flatback (Read 100386 times)
April 28, 2008, 10:23:12 AM
Reply #330
Undertow2
Reply #330 on:
April 28, 2008, 10:23:12 AM »
Yea, right. It's gonna look like crap when you're done. All you are doing is rushing through the job, not thinking anything out and basically making a huge mess. It's like you don't even care. Geesh, I mean, only 22 pages of threads, that's ridiculous. What an embarrassment.
8) 8)
She's lookin' great dude... :twisted:
April 29, 2008, 10:51:29 AM
Reply #331
MJB
Reply #331 on:
April 29, 2008, 10:51:29 AM »
LilRichard,
You're motivating me!! What a difference a coat of primer makes, coming along very nicely!!!!
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
April 29, 2008, 10:52:41 PM
Reply #332
matt 19'6
Reply #332 on:
April 29, 2008, 10:52:41 PM »
I don't mean to bring up old posts, but where did you get the foam for your stringers and does it have a name? I am ready to do my stringers and have really found your step by step posts very helpful! Any help would be great.
April 30, 2008, 08:27:48 AM
Reply #333
Reply #333 on:
April 30, 2008, 08:27:48 AM »
Why would anyone mind you bringing up old psts? That's what we post for!
Anyway, it is 2 (or 3?) pound polyurethane foam from FGCI in St Pete. It comes in 4x8 sheets , I used 2" thick board. It is REALLY easy to work with, and is not too brittle. I think I bought 3 sheets total in my hull for everything, and have a half sheet left.
April 30, 2008, 10:22:18 PM
Reply #334
DoubleL
Reply #334 on:
April 30, 2008, 10:22:18 PM »
The suspense is killing me!! What happens next??? LOL
Looking good.
What kind of primer are you using? Can you use automotive gray primer? Also I AM new... What is fairing? Same as sanding it down smooth?
DoubleL
Double L
May 01, 2008, 12:51:29 AM
Reply #335
matt 19'6
Reply #335 on:
May 01, 2008, 12:51:29 AM »
Thanks again Richard, I go up to FGCI all the time!
May 01, 2008, 06:29:13 AM
Reply #336
Reply #336 on:
May 01, 2008, 06:29:13 AM »
Double L:
Yes - fairing / sanding are the same thing.
I am using an epoxy primer made by Awlgrip called 545. You could use other epoxy primers - but I get 545 pretty cheap (comparatively).
What's next? Wear my arms out sanding, then reprime, then sand some more and paint. It's almost there.
8)
May 05, 2008, 08:01:44 AM
Reply #337
Reply #337 on:
May 05, 2008, 08:01:44 AM »
Sadly, I missed the gathering this weekend - I decided to work out my arms instead. Hit the entire hull one more time with some compound, and really focused on the corners and edges.
As you can see, I just skim coated the insides - easier than spot working, and more effective IMO. I blew through a lot of sandpaper this weekend.
Also finished a few low spots on the transom cap. You would most likely never see these imperfections (it will be non-skid) but hate to find out that's wrong later.
Will be doing some more detail work this week at night, then final priming next weekend for sure. I am getting excited.
May 10, 2008, 08:29:00 PM
Reply #338
Reply #338 on:
May 10, 2008, 08:29:00 PM »
ALRIGHT! Now we have some progress!
First I hit the entire hull with gray 545 so that I will have a guide when I sand (if you see gray - STOP sanding).
Let that coat setup, then started hitting everything with white 545 - it will be easier to spray white topcoat over white primer:
A few small runs - this was my first time using a pressure pot.
Then just for grins, I hit the transom too:
So now it is time for a light sanding, then the topcoat! Sorry for all the pictures - I am just rather excited right now... all my effort in fairing did pay off. The lines look clean, the corners are in good shape, and I only have a few small pinholes to fill.
May 10, 2008, 11:10:27 PM
Reply #339
Reply #339 on:
May 10, 2008, 11:10:27 PM »
It's really coming around Rick. I would be excited too.
May 11, 2008, 06:54:47 AM
Reply #340
Reply #340 on:
May 11, 2008, 06:54:47 AM »
LOOKING GREAT!!
May 11, 2008, 09:48:54 AM
Reply #341
Marcq
Reply #341 on:
May 11, 2008, 09:48:54 AM »
Man, with all that work done, once finish I'm sure you are not going to start another project like this, just looking at it, my arms are sore
Nice work
Marc..
May 11, 2008, 04:02:41 PM
Reply #342
Reply #342 on:
May 11, 2008, 04:02:41 PM »
Thanks guys.
Guide coated the primer today, started sanding again. Will post pics shortly.
May 12, 2008, 02:30:56 PM
Reply #343
MJB
Reply #343 on:
May 12, 2008, 02:30:56 PM »
lilrichard,
Looking good!! Progress is a beautiful thing!!
BTW, wondering what type of fairing compound you are using??
Again, nice job!
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
May 12, 2008, 03:20:01 PM
Reply #344
Reply #344 on:
May 12, 2008, 03:20:01 PM »
MJB-
Thanks.
I started with America's Cup over the bare glass - it is cheap and fills well without shrinking. Once I prime though - I have to switch to an epoxy based compound to adhere to the 545 - so I am using Interlux Watertite. That stuff is great - spreads super smooth, no pinholes, easy to work with.
22
23
24
25
31
1971 Flatback
