Author Topic: 1971 Flatback  (Read 102305 times)
May 03, 2007, 10:15:50 AM
Reply #120
« Reply #120 on: May 03, 2007, 10:15:50 AM »
Badger- thanks for kind words.
Jim- you are absolutely correct.  Although the pictures did not clearly reflect it, I did both sides the same way.  I agree- I would not fix just one side of the problem... at least not when I am this deep into the project.  However I am surprised you did not see that in picture 3 that the glass has "Stbd" written on it... you are typically WAY more observant than me!
I am hoping that the thick fillet I laid into the corner will help alleviate some of the stress by spreading the load out.  We'll see in a few years!
May 12, 2007, 06:17:18 PM
Reply #121
« Reply #121 on: May 12, 2007, 06:17:18 PM »
Alright, so made real progress for once.  Today I setup the spray rails on my boat... still need to fair out the side before mounting, but I'll do that this week.  As for now, I countersunk all the bolts and drilled all the holes.
I used 1/4" x 2" SS bolts with fender washers and nylock nuts spaced every 12".  Started drilling from the front and tightening as we went- drilling 2-3 holes at a time.  The thought is I will bolt and glue (5200) the rails back on after fairing.  One note, I decided to mount the rail with the broad side mounted to the hull.  I thought the increased bonding surface area was a plus... here is a link to the manufacturer of the rail:
http://barbourplastics.com/marine-products/R1059.htm
Here are some shots:
From the rear:
From the profile (yes, the chine is NOT finished nor fair yet) but this gives you an idea of the angle of the rail from the chine downward:
From the front looking aft:
Port side:
An example of a counter sunk bolt:
Port side finished product:
Next week is gluing them on...  btw, big thanks to "Dieseldude" from the CM site- his work helped me think through how to tackle this...
May 12, 2007, 08:59:01 PM
Reply #122
« Reply #122 on: May 12, 2007, 08:59:01 PM »
Looks good!  With the rails going that far aft you should have a real dry ride.   The pictures I took of Joel's FB  show how effective they are.  They provide a degree of lift too.
 Will you have problems fairing the chine with the end of the rail right there?
May 12, 2007, 10:16:36 PM
Reply #123
« Reply #123 on: May 12, 2007, 10:16:36 PM »
Jim-
I hope you are right... I would rather be dry.
Rails will come off before fairing... glued and bolted on after it's all set.
May 13, 2007, 06:05:57 AM
Reply #124
capnjfran
« Reply #124 on: May 13, 2007, 06:05:57 AM »
I'm confused.  shouldn't the 1 5/8 side be mounted to the hull? with the flare cupped down to flare the water away?  5200 is strong stuff and should hold just fine and with 1 foot spacing of screws - plenty strong.
Capn J Fran
May 13, 2007, 06:12:03 AM
Reply #125
capnjfran
« Reply #125 on: May 13, 2007, 06:12:03 AM »
If you get the same flare on the other edge, you should be fine. Your progress looks great.
Capn J Fran
May 13, 2007, 10:26:30 AM
Reply #126
« Reply #126 on: May 13, 2007, 10:26:30 AM »
CapnJ- I thought the 1 5/8 side should go against the hull, but upon laying it out, it just looked more sturdy and seemed less likely to fail the way I set it up.  I think it also looked better- when the 2" side was facing out, the rail looked a little clumsy.
May 13, 2007, 06:02:43 PM
Reply #127
« Reply #127 on: May 13, 2007, 06:02:43 PM »
Quote from: "capnjfran"
I think capnjfran is right, something doesn't look right there and the way you have it, it would just be a decoration instead of really knocking down the spray .... I would ask Captflatback to look at his.
May 13, 2007, 09:34:54 PM
Reply #128
« Reply #128 on: May 13, 2007, 09:34:54 PM »
If you gentlemen will notice, there is a flare on both the 1 5/8 side and the 2" side.  If you're interested, I can supply you with a section of the rail to examine... I cut off about 2' from each side.  If you look at the profile from the stern looking forward, you will see the same flare downward on the trailing edge as is on the 2" side.
The bottom line is this- sure, with 2" of deflection there might be a little less spray, but 1 5/8 inches still extends the chine much further than it was stock.  Plus it really gives a lot more bonding area to the rail...
May 13, 2007, 09:43:41 PM
Reply #129
« Reply #129 on: May 13, 2007, 09:43:41 PM »
Looks to me like you'll be in good shape the way you have it laid out.
May 14, 2007, 12:13:21 AM
Reply #130
warthog5
« Reply #130 on: May 14, 2007, 12:13:21 AM »
Richard with that surplus section of rail. You may be able to pickup a plug cutting kit and make plugs to cap off the screws for a even cleaner look.
http://www.mcfeelys.com/product/PC03-05 ... nk--Fuller
May 14, 2007, 10:12:40 AM
Reply #131
« Reply #131 on: May 14, 2007, 10:12:40 AM »
Great idea Wart!  I had planned on just filling the holes with 5200 and sanding them flush, but cutting out those plugs might be the best bet.  I will go search for those locally.
May 18, 2007, 08:00:46 AM
Reply #132
Shine
« Reply #132 on: May 18, 2007, 08:00:46 AM »
looking good Richard :)   Im not sure if you already mentioned this, but I would defiantly fair the hull sides before permanently mounting the rail.  Your going to want to move a faring board across the patch area, and the rail would get int the way.
Also, 5200 stains pretty bad - so go with the plugs if you can
Thanks for that plastic link, I was looking for some trim molding profile for our boat.
May 18, 2007, 08:09:02 AM
Reply #133
« Reply #133 on: May 18, 2007, 08:09:02 AM »
What should he use to hold the bungs in...5200?
May 18, 2007, 08:40:56 AM
Reply #134
« Reply #134 on: May 18, 2007, 08:40:56 AM »
Thanks Shine.
Jim- I was thinking 5200 would secure the plugs well...  Either way, it will be painted over.
I am going to do some serious fairing today / tomorrow in hopes of having the rails on permanently by end of weekend... if not next week.
