Author Topic: 67 - 22'2 Flatback Diver Rebuild  (Read 11697 times)
August 22, 2012, 08:57:12 AM
Re: 67 - 22'2 Flatback Diver Rebuild
« Reply #15 on: August 22, 2012, 08:57:12 AM »
All photos are very appreciated. :thumleft: Not exactly the first pics, just the first in a long time. Still.....
It appears though that somewhere down the line, the diver door hanging mechanism has been removed and the thru hull holes patched.
Not the best shot so......
One thru hole and support rod can be seen in this shot.
These appeared on the Forum back in 2006 and are buried in the Photo Gallery (taken at one of the Aqua gatherings).
It will be interesting on what you plan to do with this classic accessory (if anything) so post your pics.
August 22, 2012, 10:03:46 AM
« Reply #16 on: August 22, 2012, 10:03:46 AM »
Excellent work there CB :cheers:
Are there any owner pics of the windows?
August 22, 2012, 11:40:30 AM
« Reply #17 on: August 22, 2012, 11:40:30 AM »
Same boat as the platform
August 22, 2012, 04:41:15 PM
« Reply #18 on: August 22, 2012, 04:41:15 PM »
That first pic with the bimini is interesting. Has the spray rails added, and is powered with a 90 3 cyl Yammie.
Those windows are bad to the bone.
August 22, 2012, 08:50:07 PM
« Reply #19 on: August 22, 2012, 08:50:07 PM »
They are in a baitwell.
August 23, 2012, 10:30:48 AM
« Reply #20 on: August 23, 2012, 10:30:48 AM »
Quote from: "RickK"
It DOES look like that area has some type of plumbing. Hard to tell where it goes, etc...where the plastic circle is, there's solid glass below....
August 23, 2012, 12:49:39 PM
dirtwheelsfl
« Reply #21 on: August 23, 2012, 12:49:39 PM »
you could definitely tell my windows were in a livewell too. maybe they were trying to make the bait feel at home who knows haha.
any idea if ALL the flatbacks had the windows or just earlier ones?
August 23, 2012, 01:17:27 PM
« Reply #22 on: August 23, 2012, 01:17:27 PM »
Quote from: "dirtwheelsfl"
There is a great article on here from the 1966 Rudder magazine about the early flatbacks and optional diver model.
But dagnabbit, now I can't find it. Betcha CB knows where to look :salut:
Anyhow...the diver option had the door, AND windows. The article stated that Coburn ran the boat onto a sand beach at a fast clip to prove the durability of the windows and their "secret" method of install :shock:
Cool stuff!
August 23, 2012, 02:39:14 PM
« Reply #23 on: August 23, 2012, 02:39:14 PM »
Seek and ye shall find.
http://www.classicaquasport.com/gallery ... hp?cat=559
Article is broken up due to the scan but with a few clicks you can get the order.
Scott's memory of the "beaching" to prove window strength is correct and is found at the close.
Enjoy.
August 23, 2012, 04:05:40 PM
OldSkool67
« Reply #24 on: August 23, 2012, 04:05:40 PM »
I boxed out the lower hinges, the top holes were removed by the prev owner. I plan to replace the platform with a teak model and some custom hinges and stops. I wanted to remove the hardware from the interior of the boat and make it a little more efficent. I will post pictures of the progress with the door.
Thanks for all your info on the subject guys  :thumright:
Ive never met an alligator I didnt want to turn into a wallet and side of nuggets.
67 flatback
August 23, 2012, 04:18:55 PM
« Reply #25 on: August 23, 2012, 04:18:55 PM »
CB, good stuff bud.
OS, will look forward to see if the remnants of the window frames etc. are there when you get the floor out.
Off Topic: You ever take folks gator hunting?
August 24, 2012, 12:11:28 PM
Capt Matt
« Reply #26 on: August 24, 2012, 12:11:28 PM »
I have the original paper work on my 69 and it seems the windows where an available option.
Mine had no windows
Capt Matt
Light tackle sportfishing
August 24, 2012, 01:57:56 PM
kraw2
« Reply #27 on: August 24, 2012, 01:57:56 PM »
Thank you for taking the time to post your work. It's looking great.
August 25, 2012, 12:24:32 PM
OldSkool67
« Reply #28 on: August 25, 2012, 12:24:32 PM »
I hunt with different people every now and then. If you aking as in guided hunts no I dont. Most of the guys that do those are in the Okeechobee area and hunt off air boats. Thats not the type of hunting we do.
I have a group of guys I hunt with mainly but it really comes down to who gets tags in the lottery system. I did not get any this year but 2 good friends did. It also helps to assure your spot for the hunt when you are the guy with the boat and all the equipment.   :wink:
67 flatback
August 25, 2012, 01:19:11 PM
« Reply #29 on: August 25, 2012, 01:19:11 PM »
Gotcha. It would be neat just to go along for the ride.
