I am rebuilding a transom and was wondering if anybody would recomend the 3M epoxy resin you can find at HD? There is quite a price difference between $36.00 gal versus $98.00 for west system. i want to do it right but don't want to over spend if I don't have too.
Link to us composites. One good thing epoxy is non flammable so that saves shipping hazardous. http://www.uscomposites.com/epoxy.html
Yes, 3M is a great "marketing" company. I have never seen 3M epoxy resin at Home Depot. The only resin I have seen there is polyester. Other than the small dual mix tubes for small repairs. West system is good stuff but expensive. You need to check with US Composites and order from them. Really nice product and at a great price. I like their 3 to1 because of its cured hardness. Also don't forget that some resins aren't compatible with certain types of glass. Some have a binder on them that can only be melted off with the styrene in polyester resin.Is this the Home depot product? Or something like it?http://www.homedepot.com/h_d1/N-5yc1v/R ... C5FXN2PX8kLink to us composites. One good thing epoxy is non flammable so that saves shipping hazardous. http://www.uscomposites.com/epoxy.html
Where are you located? Your going to see if you can find a fiberglass supplier in your area. Buying your supplies at full retail is going to get expensive. Also I'm sure the stuff at Home Depot has a bunch of additives to give it a long shelf life... that equals not as strong as fresh product.
I know this is outside of the title, but MarinExpoxy is a very good product also and the price is very reasonable. It is available at http://boatbuildercentral.com/products.php?cat=41. You might want to check it out also. I have used it a few times with very little amine blush. I have also used West System and was happy with it too, but it blushes quite a bit from my experience. I would be prepared to work wet on wet if you go that route.
