Author Topic: Water Pump Maintenance, is this the same?  (Read 294 times)
August 09, 2012, 02:08:27 PM
Read 294 times
camar0
« on: August 09, 2012, 02:08:27 PM »
I have a Yamaha 2001 200HP HPDI
are these instructions the same for my motor ??
http://www.simyamaha.com/category_s/1992.htm
August 09, 2012, 02:55:12 PM
Re: Water Pump Maintenance, is this the same?
« Reply #1 on: August 09, 2012, 02:55:12 PM »
Well, it looks like the same procedure I used on my 91 200 Yam so....
Here's a link to our favorite site that has the same instructions as you show (but I can't see the photos)
http://www.thehulltruth.com/shipyard-is ... hange.html
None the less, reading through the first page of the thread seems to indicate that this procedure will work on later model Yamaha big motors.
I'd say yes but when you start to disassemble, it should become fairly obvious if this is correct.
August 15, 2012, 09:02:10 AM
merlinroad
« Reply #2 on: August 15, 2012, 09:02:10 AM »
I just did a 2003 225hp last month.
That procedure seems fine. The nice thing is no shift rod like on my Johnson.
I didn't pull the prop.
One thing to note is that the engine would not pump water on muffs. Would not piss.
When I tanked it all was good.
I actuality call Yamaha tech support about this and they it wasn't unusual to not pump on muffs.
1999 245 Explorer WAC w/ 1999 225hp Johnson, Pennington/Waretown(key harbor)
