Author Topic: 1996 200 osprey rebuild  (Read 6807 times)
August 13, 2012, 09:17:18 PM
Re: 1996 200 osprey rebuild
« Reply #15 on: August 13, 2012, 09:17:18 PM »
i plan to build up the top of the stringers, then lay the deck on top of the remainder of the old deck, ill take a pic tomorrow of a 24 morgan at work that has the deck the way i plan to do it....
edit:
heres a quick drawing what i kinda plan to do which was done on the morgan hull we have... raise the deck some, coring of some kind on top of the stringers for support...
August 14, 2012, 05:45:11 PM
« Reply #16 on: August 14, 2012, 05:45:11 PM »
today's work: dig out foam.
got most of the foam out,
the partially hidden rigging tube, need to cut it out so i can get to rest of the foam...
my work space:
August 14, 2012, 07:37:46 PM
« Reply #17 on: August 14, 2012, 07:37:46 PM »
Nice workspace  :thumleft:
and nice work so far  :thumleft:
August 15, 2012, 03:45:11 PM
tru
« Reply #18 on: August 15, 2012, 03:45:11 PM »
did you install the stereo in the sides of your gunnels?
how difficult was it to run wiring there?
August 15, 2012, 05:28:23 PM
« Reply #19 on: August 15, 2012, 05:28:23 PM »
Quote from: "tru"
it was fairly difficult to run the wires on the port side as there was no access to that side of the boat, the starboard was pretty easy
August 20, 2012, 04:34:22 PM
« Reply #20 on: August 20, 2012, 04:34:22 PM »
got the rigging tube cut out, got the most of the foam ground out, and got the motor pulled...
surprisingly, i only filled the shop vac one time today lol
August 20, 2012, 06:23:06 PM
« Reply #21 on: August 20, 2012, 06:23:06 PM »
Looking good!  Hopefully I'll have time to swing on by tomorrow morning and get a look at it in person!
August 20, 2012, 08:03:13 PM
fabuck71
« Reply #22 on: August 20, 2012, 08:03:13 PM »
what year is that 200 and how does she run?
Alex Buck
Bass Underwriters of Florida
800.528.5386
August 20, 2012, 08:17:25 PM
« Reply #23 on: August 20, 2012, 08:17:25 PM »
Quote from: "fabuck71"
she runs great. its a 1990 has somewhere around 1700 hours on her. bought from original owner a couple years ago who was anal about the maintenance.
August 20, 2012, 09:19:58 PM
fabuck71
« Reply #24 on: August 20, 2012, 09:19:58 PM »
btw, I PM'd you back :)!
Alex Buck
800.528.5386
August 21, 2012, 04:03:43 PM
« Reply #25 on: August 21, 2012, 04:03:43 PM »
got a good amount of the foam out, enough to be happy with, started digging-er, more like, vacuuming out the transom i mean mulch... pics to come! :shock:
August 21, 2012, 05:57:31 PM
« Reply #26 on: August 21, 2012, 05:57:31 PM »
heres the pics from today
whats that brown stuff on the bolts?! lol
i expected to find rotten wood, but holy crap, im surprised/lucky the motor hadn't ripped of the transom.
August 22, 2012, 08:35:31 AM
louiefl
« Reply #27 on: August 22, 2012, 08:35:31 AM »
You rebuild is going well - I'm learning as you go along.
I have a 175 Osprey and realized I'd like something a little bigger for more room, better seaworthiness, etc and have had my eye out on the 200 Osprey - same layout as the 175 but wider, longer, taller, heavier. I stumbled across this listing and thought this might be a good starting point:
http://keys.craigslist.org/boa/3206284078.html
Your mulched transon and soggy foam made me a little lightheaded - maybe I should be happy with what I have for the moment...
1996 Osprey 175 Johnson 88 SPL
August 22, 2012, 05:50:31 PM
« Reply #28 on: August 22, 2012, 05:50:31 PM »
Quote from: "louiefl"
i like the hull, drafts fairly shallow, very easy to handle alone(loading and unloading from trailer)... sometimes i do wish i had that extra couple feet of a 22-2... ill sell you a nice stripped hull lol :thumright:   the transom cap on mine wasnt sealed one bit so water just wept right in... the foam wasnt bad, the last 4-6 ft on the starboard side was wet, but not completely saturated like the transom lol
heres a video from a couple months ago running in the bay, http://www.youtube.com/watch?v=bFQgLbjFwnM
August 23, 2012, 07:43:06 AM
tru
« Reply #29 on: August 23, 2012, 07:43:06 AM »
what size motor do ou have and what kind of speeds were you seeing with it?
took mine out this weekend and ran 42 with a 150 2stroke, curious if i should see more. i also dont have a functional tac...so not sure my rpm's yet.
