Author Topic: Fish tank "Y" valve.  (Read 861 times)
August 05, 2012, 11:24:54 PM
Read 861 times
Wine Down
« on: August 05, 2012, 11:24:54 PM »
I was trying to pump both sides of the fish tanks, the port first then starboard. 1999 215 DC -this is a new boat to me...the Y valve will not turn? Am I doing something wrong? I amalso looking at addding a kicker motor primarily for safety, can anyone recommend a mounting bracket?
Phil - Wine Down
August 06, 2012, 10:03:28 AM
Re: Fish tank "Y" valve.
« Reply #1 on: August 06, 2012, 10:03:28 AM »
Y valves stick sometimes when not used.  Spray the shaft with some lubricant/penetrant and see if you can get it to move.  Sadly, sometimes corrosion causes the stem to break before the valve moves - then it's new valve time!   :x
Kicker brackets are designed based on the weight of the motor.  Spring-loaded brackets make the up-and-down process easier.  Make sure the bracket you get is designed for the weight and HP of the motor you are planning to use.  Garelick and Panther seem to be some of the most popular.  Look for stainless steel with a composite (not wood) motor mount surface.  Here are some ideas for ya:
http://www.ebay.com/sch/Boat-Parts-/264 ... or+bracket
See ya on the water!
August 06, 2012, 10:06:36 AM
« Reply #2 on: August 06, 2012, 10:06:36 AM »
Quote from: "Wine Down"
Phil - Wine Down
The diverter valve is pretty easy to disassemble, I had to take mine apart, clean and lube the spool valve.  The O-Rings dry up and with no use it gets real hard to turn.
August 06, 2012, 01:06:54 PM
Wine Down
« Reply #3 on: August 06, 2012, 01:06:54 PM »
Thanks all......I will try turning the valve without breaking it! WD 40 here we come!
August 06, 2012, 01:54:08 PM
« Reply #4 on: August 06, 2012, 01:54:08 PM »
PB Blaster... :thumright:  :thumright:
August 06, 2012, 01:56:25 PM
« Reply #5 on: August 06, 2012, 01:56:25 PM »
Yup PB blaster is the standard boat tool box item!
August 06, 2012, 07:42:49 PM
« Reply #6 on: August 06, 2012, 07:42:49 PM »
Quote
X 3
WD just doesn't hang around long enough for things that are exposed to water.
August 07, 2012, 08:05:01 PM
dxs217
« Reply #7 on: August 07, 2012, 08:05:01 PM »
I have the same boat. My fish box Y-valve is extremely difficult to access. It is located next to the bilge pump. Access is gained through small pie plate in the engine well. The baitwell/raw water Y-valve is located on the deck in front of the engine well (easy access). Both Y-valves are the same make (Bosworth).
If you can replace the fishbox Y-valve (in the bilge) without removing the engine, make a video and post it because you are a ninja and deserve serious accolades...  :)
I am not a ninja, I had the Y-valve, bilge pump, float switch, and associated wiring replaced by a mechanic during spring maintenance. He wasn't a ninja either, he removed the motor for easier access.
Now I lube the valve every couple of months with T-9. I am in the process of making a device out of PVC to turn the valve. This should make life much easier...
1999 215DC
Evinrude 200 FICHT
