Author Topic: Over heat alarm yamaha 90 higher RPM?  (Read 1302 times)
July 28, 2012, 03:11:43 PM
dburr
Re: Over heat alarm yamaha 90 higher RPM?
« Reply #15 on: July 28, 2012, 03:11:43 PM »
Hey Scott deep in the thread it says that he used white vinegar and a shot of dawn..  :thumleft:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
July 28, 2012, 07:36:00 PM
« Reply #16 on: July 28, 2012, 07:36:00 PM »
Dave, thank you sir!
Believe I will try this on my little Johnson.
July 31, 2012, 10:07:04 PM
HIFLUTIN
« Reply #17 on: July 31, 2012, 10:07:04 PM »
I Tried The vinger flush in a approx a 25 gallon tub-(one of Moms Xmas storage tubs)
Worked for approx 8 min & the over heat alarm went -off multiplie times
Water was hot in the tub so i figured that helped it.
My next step was to run a remote pump & back flush thru the piss hole with the vinegar flush without the motor running
You guys think that will work ?
August 01, 2012, 01:22:49 PM
« Reply #18 on: August 01, 2012, 01:22:49 PM »
Quote from: "HIFLUTIN"
Hi,
Did you go with the four gallons of vinegar? How much Dawn did you use?
Thanks!
August 01, 2012, 02:24:48 PM
« Reply #19 on: August 01, 2012, 02:24:48 PM »
So replacing the water pump, thermostat, and poppet valve did not cure the problem?
August 01, 2012, 04:05:07 PM
« Reply #20 on: August 01, 2012, 04:05:07 PM »
Quote from: "fitz73222"
In addition to that question, how much residue did the vinegar get out?
August 02, 2012, 08:01:59 AM
HIFLUTIN
« Reply #21 on: August 02, 2012, 08:01:59 AM »
Is what the yamaha people call the pressure comtrol valve & the Poppit valve the same thing?
August 02, 2012, 08:05:48 AM
HIFLUTIN
« Reply #22 on: August 02, 2012, 08:05:48 AM »
Quote from: "slvrlng"
I used a gallon the first time with prob 6 gallons of water.
Have been back flushing thru the pee hole with out running the motor.
Tonight iam going to flush with muffs & water hose to see what I get
August 02, 2012, 08:22:38 AM
« Reply #23 on: August 02, 2012, 08:22:38 AM »
Yes...
September 02, 2012, 04:53:42 AM
HIFLUTIN
« Reply #24 on: September 02, 2012, 04:53:42 AM »
Took out Sat AM-Did not get alarm
Did the Vinger flush looked at thru the thermostat cover before & after
definite was a difference- lot cleaner.
Changed Thermosate & POP valve
Not sure what what it was that kept kickin alarm but hopefully gone for good
September 02, 2012, 07:20:36 AM
« Reply #25 on: September 02, 2012, 07:20:36 AM »
Glad to hear you got past the issue... I was wondering what happened, part of giving technical advice is the feedback and whether or not it worked.
