Gallery
Gallery
Aquasport Discussion
Aquasport 246 on E Bay...Purchased by a new member
Topic: Aquasport 246 on E Bay...Purchased by a new member (Read 2198 times)
July 14, 2012, 11:42:48 PM
Purgatory
Re: Aquasport 246 on E Bay...Purchased by a new member
Reply #15 on:
July 14, 2012, 11:42:48 PM »
The deck at the transom (factory) is a waste of space. First thing to change IMHO. This will also aid with your entry concerns.
Glad you've joined. It is apparent that you have a good understanding of boats...good deal.
Also glad that you like the twins.
Welcome... thanks, and keep us posted
July 15, 2012, 02:32:58 AM
Reply #16 on:
July 15, 2012, 02:32:58 AM »
Very nice
Seems to be in good shape and definitely a rare model.
The twins will always be in your way when trying to get back into the boat. Not sure what to rig up to make it easier
You have a finite amount of room between the corner and the engine and still allow the engine to function properly in a turn.
Congrats.
July 16, 2012, 11:06:54 AM
Georgie
Mechanical Master
Reply #17 on:
July 16, 2012, 11:06:54 AM »
Well, she was delivered late last night in the rain. Preliminary report is that the deck is amazingly still rock solid. Now I'm just praying to get lucky with foam/stringers, fuel tank and/or electrical/cabling. Lower units are admittedly pretty gross though. Won't be a fun cleanup project.
Overall Port Side
Port Bow
Lower Units
Port Close-up
Stbd Bow
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
July 16, 2012, 11:10:14 AM
Purgatory
Reply #18 on:
July 16, 2012, 11:10:14 AM »
Looks like the engines were left down on purpose....for sure both tilts aren't broken
July 16, 2012, 11:18:19 AM
Georgie
Mechanical Master
Reply #19 on:
July 16, 2012, 11:18:19 AM »
Yeah, the ebay ad indicated at least one was leaking (slowly lowering the engine), but I have a complete working replacement at home with new solenoid as well as the correct size spanner wrench to take off the cylinder caps and replace the seals if necessary (just replaced the seals in the T/T on my wellcraft this year). The o-ring sets are actually pretty darn cheap. I guess I figure at the very least I can make two working units out of the three I'll have without needing to buy a ton of expensive or obsolete parts. Sure woulda been nice of the PO to raise the engines and lever-lock them though when she was sitting in the water.
Ryan
1979 246 CCC
July 16, 2012, 03:12:23 PM
Reply #20 on:
July 16, 2012, 03:12:23 PM »
Sure is a pretty sight isn't she - truly a rare bird. Just need a little TLC.
Congrats.
July 16, 2012, 08:33:56 PM
Mechanical Master
Reply #21 on:
July 16, 2012, 08:33:56 PM »
Must be good to have her home - looks good for a start - not too much obvious stuff there.
July 16, 2012, 08:37:27 PM
Global Moderator
Reply #22 on:
July 16, 2012, 08:37:27 PM »
Love the tower.
July 16, 2012, 09:03:40 PM
jahoward1
Reply #23 on:
July 16, 2012, 09:03:40 PM »
She's gonna be a beauty.
1997 Aquasport 200 Osprey
"Sally May"
July 16, 2012, 09:04:25 PM
Group W Bench
Reply #24 on:
July 16, 2012, 09:04:25 PM »
That thing is sweet. Slap some Suzuki DF140s on that baby and it would be a little fuel miser even with twins. If you ever decided to do some modifications, you could eliminate the splashwell completely so any water would flow right out the transom like on a Calcutta catamaran. I would hate to start messing with such an unmolested original though.
July 16, 2012, 09:42:46 PM
Purgatory
Reply #25 on:
July 16, 2012, 09:42:46 PM »
That was my thinking, the splashwell seems lengthy off the engines/intrusive to the cockpit.
To the extent that it isn't structural....shouldn't be much to it. But that can come, or not, anytime.
Damn good looking boat. And as Rick says, great to have a new "bird" flying around the house
July 16, 2012, 11:14:24 PM
Purgatory
Reply #26 on:
July 16, 2012, 11:14:24 PM »
Run those 140 Johnsons. You're an OMC guy, and they aren't costing you a nickel. If they burn some extra fuel, so be it.
Takes a lot of gas on a daily basis to justify the price of new four strokes. Besides...the smell of twin two strokes at 5 am....Priceless
July 17, 2012, 12:42:11 AM
Reply #27 on:
July 17, 2012, 12:42:11 AM »
She will be some work but i think you found a diamond in the ruff
July 17, 2012, 10:22:19 AM
Capt Matt
Reply #28 on:
July 17, 2012, 10:22:19 AM »
Sweet ride, first one like it I have ever seen
You got a deal even if its just for the hull, Its not only how much gas the motors burn its the fact you want to enjoy your boating and with two old motors like that there will pretty much always be a problem with at least one. If you want to use the boat to its ability you will need some new power. Those old OMC's are good for killing mosquitoes if they start though.
Good luck with your new boat
Capt Matt
www.captmattmitchell.com
Light tackle sportfishing
July 17, 2012, 10:42:53 AM
Georgie
Mechanical Master
Reply #29 on:
July 17, 2012, 10:42:53 AM »
Appreciate the compliments - It's going to be a LONG time before I can afford to repower her (wedding bills, student loans, new homeowner, no raises in the foreseeable future, etc.
), but in the meantime I get a pair of generally very reliable engines that I already know how to completely rebuild, won't have to pay experts to repair, and can often even fix on the water in a pinch if anything goes wrong. Still can't get over the condition of this thing after 33 years...
Here's some more p0rn...
Starboard Engine Fore
Starboard Engine Aft
Tower Up
Electronics Box full of antiques (I'm betting I might be able to find a sextant in there if I look hard enough)
Console
Ryan
1979 246 CCC
