Author Topic: 2000 Aquasport 215 Osprey Dual Console Fishbox Hardware  (Read 1627 times)
July 07, 2012, 02:18:01 PM
Read 1627 times
who4ever
« on: July 07, 2012, 02:18:01 PM »
Ahoy mateys.  I know I've asked this before but I'm going to ask it again.  My 2000 215 Osprey Dual Console is in need of fishbox lid repair.  I have 3, one long one down the middle between the dual consoles, and 2 in the stern, on the port and starboard.  The lids are attached to the deck with Gem Lux hinges.  The hinges are secure where they attach to the deck, but where they attach to the lid are in need of repair.  They seem to be attached to the lid with a screw through the top, which fastens into a piece of hardware that I don't recognize, I don't know what to call it, and where to get it.  The hardware looks like a metal washer, with a threaded cylindrical attachment projecting on one side, almost looks like a top hat.  The cylindrical part is inserted into the hole drilled into the lid from the bottom, and the screw screws into it from the top.  It also looks like after the screw is secured, the part that projects from the hardware is snipped or hacksawed off flush with the hardware so when the lid is closed, the bottom of the lid sits flush with the lip in the deck that is supposed to keep the water out.
Here are some pictures.  The first is of the hinge looking down on it with the lid closed:
This is of the hardware with the lid open.  This is an example of a hinge that does not need repair (except for the rust):
This is an example of a hinge badly in need of repair:
And finally, this is a picture of the screw and unidentified fastener that I'm looking for:
Do any of you recognize the hardware?  Know what it's called?  Know where to get it?  Know the proper size to order?  Is this original Aquasport hardware?  And, am I correct in assuming that after screwing the screw, the end was cut off?
If anyone can help, I, as always, would greatly appreciate it.  Thanks
Dave
July 07, 2012, 02:56:38 PM
xo4001
Re: 2000 Aquasport 215 Osprey Dual Console Fishbox Hardware
« Reply #1 on: July 07, 2012, 02:56:38 PM »
They called T nuts or propel nuts
Google it and its available at plenty stores
Good luck
1971? Aquasport 240 Seahunter
H254
2 X Merc 115 4s
July 07, 2012, 05:02:32 PM
« Reply #2 on: July 07, 2012, 05:02:32 PM »
Those are the original,Seabob said they where called Tophats!Tou also could replace them with a stainless flat washer and lock nut.
http://classicaquasport.com/smf/index.php?topic=9118.0
July 07, 2012, 06:12:37 PM
who4ever
« Reply #3 on: July 07, 2012, 06:12:37 PM »
Pete, can't do that.  The lid won't close all the way then.  Look at the damage the idiot who put the screw in did to the lip on the deck.
August 02, 2012, 06:57:19 PM
Wine Down
« Reply #4 on: August 02, 2012, 06:57:19 PM »
I cannot really help you with your question but I am wondering if you can help me. I just purchased a 1999 215 DC, do not know if it an Osprey or not. My question is I aslo have a fish well on the port and starboard - long and narrow. They each have a drain that pump out. When I turn the pump on only the port side pumps out? Am I doing something wrong or do I have an issue?
If you can help that would be great.
Phil
