Normally the bulb is a dual element bulb. One for the run lights and one for the brake/turn and the brake/turn element should burn brighter.-bad bulb-corroded bulb-corroded socket-wire broken internally-corroded splice-corroded ground if it's connected to trailer frame(I can probably think of more )
Okay. The Wesbar capsule that I have is number 3348. I bought it about 10 years ago for a trailer that I no longer have.Red wire is brake/turn signal.Black wire is running light.White is ground.The colors I gave above are for standard trailer wiring harnesses.Here is the one I have.http://www.easternmarine.com/wesbar-sea ... psule-3348You can have it if it will fit. The package is falling apart but it's new. If you want it PM me your shipping address.
