Author Topic: Fuses  (Read 1701 times)
July 05, 2012, 09:29:51 AM
Read 1701 times
taylorw13
Fuses
« on: July 05, 2012, 09:29:51 AM »
Can anyone tell me where the fuse box/block is located on a 99 175 osprey for gauges and switches?
1999 175 Osprey with 2000 115 Johnson
July 05, 2012, 10:25:48 AM
Re: Fuses
« Reply #1 on: July 05, 2012, 10:25:48 AM »
Welcome aboard!!!
Without pics my best guess is they are inside the console. Post some up to confirm!
Is your battery in the console?
July 05, 2012, 11:08:32 AM
taylorw13
Re: Fuses
« Reply #2 on: July 05, 2012, 11:08:32 AM »
Yes my battery is in the console, and I was looking for the fuses the other day and could not find them, I traced the wires and didn't see any fuses
July 05, 2012, 02:15:13 PM
Re: Fuses
« Reply #3 on: July 05, 2012, 02:15:13 PM »
you shouldn't have fuses on the 99 model, it should have small round breakers that pop out when tripped.  They should be located adjacent to the switch for whatever component you are switching.  what problems are you having?
July 05, 2012, 06:07:48 PM
taylorw13
Re: Fuses
« Reply #4 on: July 05, 2012, 06:07:48 PM »
My fish box pump out isn't working, my nav lights not working, trim gauge works sometimes, gas gauge not working, not sure if water temp works, alarm gauge, or volt gauge. My Rpm gauge works and all other switches and lights work.
July 05, 2012, 09:54:05 PM
Re: Fuses
« Reply #5 on: July 05, 2012, 09:54:05 PM »
Quote from: "taylorw13"
Taylor,
Keep in mind that the boat's electrical system (pumps, lights, horn, etc.) are separate from the engine's electrical systems (ignition, gauges, trim/tilt, etc.) save for a common ground.  Since you have failures on both sides of the equation, it stands to reason that there is a loose ground somewhere...
Now, the fun part is to try and find it.  I'd start with the batt... :thumright:
July 06, 2012, 09:38:58 AM
Re: Fuses
« Reply #6 on: July 06, 2012, 09:38:58 AM »
Aside from that, what's your problem?   :scratch:   See SeaBob's comment.
June 17, 2013, 01:48:55 PM
taylorw13
Re: Fuses
« Reply #7 on: June 17, 2013, 01:48:55 PM »
Ok so I have figured out my fish box pumpout pump was cracked, and all my gauges and switches are working except for my nav lights and horn. I still think I have a loose ground somewhere because sometimes while out on the boat if I hit a wake my gauges will go out but if I turn the boat off and on they start working again.
June 17, 2013, 02:45:21 PM
Re: Fuses
« Reply #8 on: June 17, 2013, 02:45:21 PM »
I wonder if he having the same piggybacked power jumper spade connecter problem I was having.
