Author Topic: Outboard trim  (Read 438 times)
July 03, 2012, 09:53:45 AM
Read 438 times
LocoLouie
Outboard trim
« on: July 03, 2012, 09:53:45 AM »
I have a 200 Evinrude Oceanpro on my 21.5 Explorer Aqua.  The other day, while cleaning the boat, I raised the motor with the trim button and now it is stuck in the upward position.  I can hear it whirl, but it does not move up or down and it seems to get stuck.  The only way to make the whiring stop is to switch off the battery.  I'm not mechanically oriented but there a quick fix, I can handle that.  If not, here we go $$$$$.
Help!!! and Thanks, :pale:
Lou
Luis "Lou" Rosado III
Port Orange, FL
July 03, 2012, 11:39:10 AM
Re: Outboard trim
« Reply #1 on: July 03, 2012, 11:39:10 AM »
Stuck trim switch or stuck "up" relay. Find the black 1" X 1" X 1" cubes under the cowling and unplug them and switch them and try again. If the engine only trims down then you have your answer for the relay. For the trim switch, unplug the switch from the harness and test for continuity with a volt /ohms meter and see if the switch is stuck closed.
July 03, 2012, 05:08:15 PM
LocoLouie
Re: Outboard trim
« Reply #2 on: July 03, 2012, 05:08:15 PM »
Thanks for the info.  hopefully it wili save me some $$$.
Lou
Port Orange, FL
July 12, 2012, 12:10:35 AM
LocoLouie
Re: Outboard trim
« Reply #3 on: July 12, 2012, 12:10:35 AM »
Thanks a million to fitz73222 - Your advise on the trim issue was spot on.  It's working well again...  Thanks for the guidance.
Lou  :cheers:
Port Orange, FL
July 12, 2012, 05:45:50 AM
Re: Outboard trim
« Reply #4 on: July 12, 2012, 05:45:50 AM »
Quote from: "LocoLouie"
Lou  :cheers:
Hey Loco,
I'm just up the road from you in Palm Coast. What was the fix?
