Author Topic: Hose type Deck Fill for Water  (Read 596 times)
July 01, 2012, 08:20:10 AM
Read 596 times
dxs217
« on: July 01, 2012, 08:20:10 AM »
My Water Deck Fill on '99 215 is corroded bad. I'm trying to replace but every Water Deck Fill on the market doesn't match the dimensions. They are all too small in diameter. The only deck fills I can find with the correct dimensions are for "Gas" or "Diesel".
Does anyone know where I can find a Hose Deck Fill labeled "Water" with these dimensions:
A: 1-1/2"
B: 2-3/16" (as long as it's great than 2" it should work)
C: 2-3/4" (this is the one I can't locate, every one I found online is 2-3/8")
Any help is appreciated.
V/R
1999 215DC
Evinrude 200 FICHT
July 04, 2012, 07:46:42 AM
dxs217
Re: Hose type Deck Fill for Water
« Reply #1 on: July 04, 2012, 07:46:42 AM »
Seabob,
Do you what company made these deck fills for Aquasport? The old one has no name anywhere on it.
1999 215DC
Evinrude 200 FICHT
July 04, 2012, 01:36:00 PM
« Reply #2 on: July 04, 2012, 01:36:00 PM »
Most likely Perko, but could also have been Whitecap.  Let me look...
July 04, 2012, 01:46:03 PM
« Reply #3 on: July 04, 2012, 01:46:03 PM »
Have you looked at this one from Whitecap?  http://www.whitecapindustries.net/produ ... ductId=174  Reason I went with them is that we were using quite a bit of Whitecap hardware at the time your 215 was built...
July 04, 2012, 11:25:14 PM
July 06, 2012, 08:28:45 AM
« Reply #5 on: July 06, 2012, 08:28:45 AM »
Not sure if you found one of these yet. As long as nylon would work Seadog makes one that fits your pattern. part # 354-3570331   list price is only $11.25
July 08, 2012, 05:55:41 PM
dxs217
« Reply #6 on: July 08, 2012, 05:55:41 PM »
The flange on the Whitecap is too small (3"). The seadog size is correct but was looking for a metal deck fill.
Thanks for the replies, if anyone has seen or purchased one with the dimensions above (metal) please let me know.
Dan
1999 215DC
Evinrude 200 FICHT
July 11, 2012, 10:27:56 PM
« Reply #7 on: July 11, 2012, 10:27:56 PM »
