Author Topic: Bimini frame morphed into a dodger frame?  (Read 484 times)
June 25, 2012, 04:04:46 PM
Read 484 times
daniel123
« on: June 25, 2012, 04:04:46 PM »
Any thoughts on converting a Bimini support frame into something suitable as a frame for a dodger? With some additional framing and the legs cut down, 'think it would work?
June 25, 2012, 05:29:30 PM
Re: Bimini frame morphed into a dodger frame?
« Reply #1 on: June 25, 2012, 05:29:30 PM »
Yes dodger frames are typically made using the same hardware and tubing as a bimini.  Only a dodger frame is typically fully curved.
June 25, 2012, 06:06:45 PM
daniel123
« Reply #2 on: June 25, 2012, 06:06:45 PM »
Hey Wingtime; thanks for chiming in. Mine are curved, but would have to be cut down height-wise and the bends adjusted to assume a rounded dodger shape. Think that's practical with s/s tubing?
June 25, 2012, 06:32:48 PM
« Reply #3 on: June 25, 2012, 06:32:48 PM »
well bimini frame would have bends and maybe a crown to it... but a dodger should be radiused closely to the shape of the bow area.
June 25, 2012, 09:45:03 PM
« Reply #4 on: June 25, 2012, 09:45:03 PM »
I agree with Mr.Wingtime....While a bimini an a dodger are similiar they are very different,a bimini is relatively flat a dodger has a lot of compound curves.You may be able to make a dodger out of a bimini,but it may require more effort than its worth,and the end result might not be what you want.But hey,go for it!Just my .02,good luck! :cheers:
