Author Topic: Transom Saver Question  (Read 1069 times)
June 22, 2012, 05:42:51 PM
Read 1069 times
daniel123
« on: June 22, 2012, 05:42:51 PM »
I have a 200 Osprey on a trailer with the aft roller/beam tucked up under the transom out of a direct line-of-reach for the trailer-end of a traditional transom-saver. There is no part of the trailer far enough aft against which to directly brace the spring-loaded saver-shaft. Any ideas?
June 25, 2012, 03:59:32 PM
daniel123
Re: Transom Saver Question
« Reply #1 on: June 25, 2012, 03:59:32 PM »
I found a T-saver from Attwood that has an extended, bent shaft designed for such applications which I have ordered and will try out.
November 03, 2012, 02:14:32 PM
skyliner4444
« Reply #2 on: November 03, 2012, 02:14:32 PM »
Same issue with my trailer. I picked up a M-Y Wedge and it works great. I believe others on here have it as well.
http://www.m-ywedge.com/
November 03, 2012, 02:20:02 PM
« Reply #3 on: November 03, 2012, 02:20:02 PM »
Quote from: "daniel123"
Customer of mine uses that exact same transom saver (with the "bent" support tube) on his Ranger flats boat.  No problems at all...
