Author Topic: Manual Lever on Primer Solenoid - 1986 175 Johnson  (Read 643 times)
June 22, 2012, 12:57:48 PM
Read 643 times
ktisdall
  • NorthEast
« on: June 22, 2012, 12:57:48 PM »
I bought an early-eighties 200ccp with 1986 175 Johnson over the winter and I'm just getting it sorted out now.   Got the engine started yesterday but I am not clear on the small lever on the primer solenoid.  The solenoid sits on the starboard side of the engine.  At the moment I'm not sure if I have it "ON" or "OFF".
If you look at a parts diagram of the engine, I believe the lever is #27 on the intake manifold fiche section.
Any thoughts?
--Kevin
June 22, 2012, 02:20:38 PM
ktisdall
  • NorthEast
Re: Aquasport CCP Series - boats and owners at Classic Aquas
« Reply #1 on: June 22, 2012, 02:20:38 PM »
Anyone home?
I have a 1981 200ccp and will need a fuel tank sooner than I thought.  I expect the best way is to remove the old one for measurements.    But just being hopeful: can anyone say for certain what the tank size in these was and where to get one?  Any possibility there is someone making a drop-in replacement?
I know this is wishful thinking but a guy can dream, can't he?
--Kevin
June 22, 2012, 03:05:17 PM
Re: Manual Lever on Primer Solenoid - 1986 175 Johnson
« Reply #2 on: June 22, 2012, 03:05:17 PM »
MOD Edit:
Alright, I merged these two posts and will try and give you direction on both.
First the solenoid:
viewtopic.php?p=72539#p72539
I'm not sure if this is what you're looking at but it is a primer solenoid.
Now the tank:
viewtopic.php?p=39818#p39818
viewtopic.php?p=19876#p19876
Most tank builders shown have built Aqua replacement or furnished OEM to Aqua. They have dimensions but can also build custom.
The Resource forum is your friend.
I merged your posts because the tank inquiry was placed in the CCP registry. You'll get a better response here. A lot of tanks have been replaced by members on this Forum. We kinda have that aspect of rebuilding down
"Anyone home"?  kinda says it all. :mrgreen:
First one's are always free.
Good luck. :thumleft:
June 22, 2012, 03:08:19 PM
« Reply #3 on: June 22, 2012, 03:08:19 PM »
Quote from: "ktisdall"
Anyone home?
--Kevin
There are no drop in replacements. You have to yank the tank anyway; have one custom built to match the original exactly. $10 per gallon to build one.
June 22, 2012, 09:16:41 PM
« Reply #4 on: June 22, 2012, 09:16:41 PM »
I think your tank should be the same size as what was in my 200xf that I replaced.  It should hold 73 gallons and is 72" long.  I have a drawing for it.  As already mentioned the rule of thumb is about ten dollars per gallon.
July 05, 2012, 03:06:19 PM
ktisdall
  • NorthEast
« Reply #5 on: July 05, 2012, 03:06:19 PM »
Thanks all - especially Cap't Bob for extra patience.  Very helpful links.
I have run the boat now in the water vs on the hose.  Seems to be ok, starts right up, runs ~32-35mph at 4750 rpm.   The biggest fuel tank issue is that the sending unit is sketchy. I did get enough corrosion off it to get it working but I can't get it out for replacement.   I'm now hoping it lasts the season and I'll get into it in the fall/winter and get the tank replaced.
Again, thaks for the info.  Will probably got the take it out/measure/replace it route.
--Kevin
