Aquasport Discussion
looking to get an idea on resale value
Topic: looking to get an idea on resale value (Read 372 times)
June 16, 2012, 08:20:31 PM
Read 372 times
OldSkool67
June 16, 2012, 08:20:31 PM »
I just bought a boat with a 235 evinrude - 1985
it runs great, no known problems, includes prop.
any idea on price for resale. 1000??
Ive never met an alligator I didnt want to turn into a wallet and side of nuggets.
67 flatback
June 16, 2012, 08:29:22 PM
Global Moderator
Re: looking to get an idea on resale value
June 16, 2012, 08:29:22 PM »
$1000 sounds right to me, maybe even $2000.
June 16, 2012, 08:37:19 PM
Purgatory
June 16, 2012, 08:37:19 PM »
Put it on Craig's for $1400, take the first thousand bucks cash that shows.
June 16, 2012, 09:42:22 PM
Rigging Master
June 16, 2012, 09:42:22 PM »
I'd go with Bob's figure...$2K, if the response is weak, drop down to $1600. But don't let it go a week and then drop, give it some time. Yes, the 235s are gas hogs, but a lot of power for $1500 to $2K is a good deal...
June 16, 2012, 10:49:35 PM
June 16, 2012, 10:49:35 PM »
Depends on how clean it looks... but I'd say a good running motor is worth at least $1500... as already said put in on CL for $2000 or $1995 and see what happens.
June 16, 2012, 11:18:40 PM
Purgatory
June 16, 2012, 11:18:40 PM »
Guys....pretend you're a buyer...would you buy an eighties 235 at 2K?
If so....pay 1K and make some money at $1600.
Or.. I'm wrong. In Florida maybe it will bring 2K. But not here.
June 17, 2012, 06:32:16 PM
Capt Matt
June 17, 2012, 06:32:16 PM »
We call those motors "too thirsty fives"
Should be worth $1200-$1500 if it runs
Still cheap for that much power and lots of guys still run these old OMC motors as they are simple to work on and run forever.
Capt Matt
www.captmattmitchell.com
Light tackle sportfishing
June 17, 2012, 11:23:32 PM
Mechanical Master
June 17, 2012, 11:23:32 PM »
The 235s were gas hogs and always ran a bit rough due to their design. OMC took the 90 degree V-4 block and just added 2 cylinders to make the old V-6.
A 90 degree V-4 is pretty well balanced, but a 90 degree V-6 is not. :( You can make up for the imbalance with balance shafts or a split crankshaft, but OMC did not do that. If you wind an early OMC V-6 up very tight - it will come apart. But run them a bit rich, lots of oil, don't overheat, and keep the RPMs low and, like most marine engines, they will run for a long time with no real problems.
What's interesting is that if you add 2 more cylinders to the V-6, you wind up with a 90 degree V-8 that is a very well balanced engine. OMC did that with the 275/300 engines. Those old V-8 OMCs were heavy and drank like a submariner on shore leave, but were smooth and powerful. It would be interesting to see what would happen if you took that OMC V-8 (4 liter) engine today and made it direct injection.
