Good work.The blisters behind the stainless transom plate were caused by held water. No biggee...gonna be new.The plywood in the cap looks good How is the floor?
I plan to close in transom, put a tuna door in, and build in a livewell.The transom seemed solid before I started but did find some wet spots and a rotten area. i found the rotten areas at the end of cutting out the plywood which i was gratefull for because it was really tough going. After tearing the transome out I give a lot of credit to those who have done this before.I dont plan to tackle the floor right now since it seems solid.I have a 6 year old son asking me on the hour when I am working on the boat "are you finished yet" and " the boat is going to look real cool right". I will post some pictures this week of my progress.
Fish,Swap out that strainer for a forced water clamshell pickup. Perko makes a nice one, bronze, 3/4 inch.Will fit the same hole.Jdupree has your boat, he switched out, priming issue solved.
Quote from: "fishinonthebrain"I plan to close in transom, put a tuna door in, and build in a livewell.The transom seemed solid before I started but did find some wet spots and a rotten area. i found the rotten areas at the end of cutting out the plywood which i was gratefull for because it was really tough going. After tearing the transome out I give a lot of credit to those who have done this before.I dont plan to tackle the floor right now since it seems solid.I have a 6 year old son asking me on the hour when I am working on the boat "are you finished yet" and " the boat is going to look real cool right". I will post some pictures this week of my progress.I also am plan on putting in a closed transom. I wasn't so lucky with the floor thought. When I bought the boat I was just going to pull the tank and throw in a poly tank. Once i started pulling the screws out i found that ever screw was wet. Then I found a soft spot right next to the console. Looked like someone had cut a larger hole where all the wires and controls came through which caused water to get into the wood. So I plan on just pulling the entire deck up and all the foam and starting from scratch. Have you found anything on separating the insert, floor and gunnels, from the hull? I have been thinking about it for awhile and I just don't want to do a half a$$ job on it. I would like it to be as good if not better then it was coming out of Aquasport.
Quote from: "gran398"Fish,Swap out that strainer for a forced water clamshell pickup. Perko makes a nice one, bronze, 3/4 inch.Will fit the same hole.Jdupree has your boat, he switched out, priming issue solved.I did a search of the clam shell your talking about and found that you can buy it separate from the thru hull fitting. Can I use my thru hull fitting, shutoff and just buy the clamshell? The clam shell is just screwed onto the hull where the thru hull fitting is coming through the hull.
