Trailers
Replacing fenders
Topic: Replacing fenders (Read 1674 times)
June 14, 2012, 06:44:40 PM
Read 1674 times
daniel123
Replacing fenders
June 14, 2012, 06:44:40 PM »
My 200 Osprey came on a nice Continental aluminum trailer, nice but for one fender, which took a hit hard enough to split it. The former owner said it might have been caused by a (darn violent) blow-out. Anyway, I need to fix or replace it. Any ideas or advice welcome; photo below.
June 14, 2012, 06:46:53 PM
Re: Replacing fenders
June 14, 2012, 06:46:53 PM »
Contact Continental.
June 14, 2012, 07:42:35 PM
Rigging Master
June 14, 2012, 07:42:35 PM »
Without seeing said pic, those are the molded plastic ones, correct? With the little step pads on each end of the fender?
June 14, 2012, 08:46:59 PM
June 14, 2012, 08:46:59 PM »
http://www.continentaltrailers.com/Wate ... _parts.pdf
June 14, 2012, 09:02:17 PM
Rigging Master
June 14, 2012, 09:02:17 PM »
P/N 17-8583 or 8584, depending on size of tires...
June 15, 2012, 03:02:26 PM
June 15, 2012, 03:02:26 PM »
Where you located? those fenders are a standard part that you should be able to find locally.
June 15, 2012, 05:53:14 PM
June 15, 2012, 05:53:14 PM »
Yep. Sturdybuilt in Bradenton carries just about any fender one could imagine in single, dual, and triple. Plastic, galvanized, stainless, aluminum, and painted.
June 15, 2012, 08:23:41 PM
June 15, 2012, 08:23:41 PM »
There's a SturdyBuilt in Sarasota too, about 3/4 mile south of Bee Ridge on 41 - west side.
June 21, 2012, 03:56:25 PM
daniel123
June 21, 2012, 03:56:25 PM »
Sorry I wasn't monitoring this link like I should have; I didn't expect so much quick help! The fenders are aluminum diamond plate. I'll contact Continental and then look locally here in Columbus, Ohio. The tires are standard 25 inch, I believe.
June 21, 2012, 04:36:46 PM
daniel123
Reply #9 on:
June 21, 2012, 04:36:46 PM »
Just off the phone with Continental (Based on the catalog link you sent, I need one model 53 F1315 RA aluminum diamond plate fender: $42.50) and they don't sell retail (so that price is wholesale?) or have dealers outside of FLA!
June 21, 2012, 04:53:10 PM
Global Moderator
Reply #10 on:
June 21, 2012, 04:53:10 PM »
I replaced my galvanized ones on my old CCP trailer with Diamond Plate. Generic stuff I got at the local trailer repair shop but you may find it on line.
Here's a start.
http://www.rockettrailers.com/PartsBook ... enders.htm
June 21, 2012, 06:06:09 PM
daniel123
Reply #11 on:
June 21, 2012, 06:06:09 PM »
Thanks, Bob, but I need aluminum to match the good one and I have the feeling I may not be as handy at fabricating as thee....
Are there boat trailer "pick and pull" graveyards out there?
Dan
June 21, 2012, 09:06:19 PM
Global Moderator
Reply #12 on:
June 21, 2012, 09:06:19 PM »
I thought these were aluminum.
I replaced my galvs. with alum. and the replacements were that diamond plate design. Just need to measure your old and search.
June 22, 2012, 05:17:09 AM
Reply #13 on:
June 22, 2012, 05:17:09 AM »
I thought I saw a few different fenders available at Sturdybuilt. Did you check their website?
June 22, 2012, 11:30:05 AM
daniel123
Reply #14 on:
June 22, 2012, 11:30:05 AM »
Will do now...
Trailers
Replacing fenders
