Ended up sanding down the gelcoat area that had the crazing. The gelcoat is really thin on the bottom by the bow. Bought a West System book about crazing and gelcoat so following the info on grinding out cracks, wiping with alcohol, and filling with epoxy filler.Planning on painting the boat with Awlgrip instead of gelcoating. Lots of epoxy hull repair so gelcoating is probably out.Thanks for the info about your experience with Durabak JD.I read your writeup about it on here and on THT. Sounded/looked like it was having issues cracking because the surface below it was cracking. My entire interior is brand new and I didn't think I would have to worry about that. Found a couple other write ups about the best way to clean Durabak but I know if I am not careful it will stain for sure. I may end up doing Kiwigrip on floor and cap with Durabak just on the hull vertical walls. There are so many good and bad reviews about every non-skid on the web it can make your head spin.Got 2 gallons of textured and one quart of smooth per recommendation of the guys at Durabak. They said once I lay down 2 layers if I think it is too aggressive just roll a smooth coat over it.
Wow, looks/sounds like you've been busy
