Can anyone tell me if I've re-done this battery wiring correctly? (or incorrectly as the case may be...)
The middle battery is my starting battery, I've got the ground from the motor on this one and the positive going to switch post 1.
I've got the two accessory batteries wired in parallel, with a positive lead from that bank going to switch post 2.
Red starting wire is on common on the switch. The accessories are hard wired into battery two at the moment. (The accessory wires don't reach the common post on the switch. I'll fix that later.)
Here's my question, On the perko diagram it looks like they've got the negative wires of the two batteries linked, going to the ground on the motor. Should I have the negative from one of the batteries in the parallel bank going to the negative on my starting battery?
