Author Topic: flexible trim for the side rod holders  (Read 565 times)
June 04, 2012, 11:49:18 AM
Read 565 times
HIFLUTIN
« on: June 04, 2012, 11:49:18 AM »
Any sources for the white flexible trim for the side rod holders.
I know TACO has it but they seem proud ($) of it
June 04, 2012, 11:53:41 AM
Re: flexible trim for the side rod holders
« Reply #1 on: June 04, 2012, 11:53:41 AM »
HF,
Is this what we would call a J-trim?  Check with Barbour Plastics as well as Trim-Lok.  You also might want to call Marine Surplus in Bradenton, see if they have some old stock, doesn't necessarily have to be Aquasport, as a lot of builders use that type of trim.  Probably MCL over in Ft. Pierce has some, but I figure Sarasota is a little closer to you....
