Author Topic: Removing Boot Stripe  (Read 1307 times)
April 08, 2006, 04:31:35 PM
Read 1307 times
dusky
« on: April 08, 2006, 04:31:35 PM »
I am working on a 1987 170 rebuild (will post pics soon) and am wondering the best way to remove an ORANGE boot stripe?
I plan on priming the hull white and painting it white after I get it off, or some of it off.
1987 17ft, 80s 115 Merc
North Shore, MA
April 08, 2006, 04:57:08 PM
« Reply #1 on: April 08, 2006, 04:57:08 PM »
Easy Off oven cleaner will work without attacking the gelcoat.  Follow the safety precautions on the label.
April 08, 2006, 07:13:45 PM
Mr. Osprey
« Reply #2 on: April 08, 2006, 07:13:45 PM »
I scraped it all off with the blade of a razor knife. Just be extra careful not to scrape the gelcoat. (Learned that from experience).
Mr. Osprey
1971 Mako 17 Angler
1986 Evinrude 88 SPL
April 08, 2006, 08:24:52 PM
Stripes
« Reply #3 on: April 08, 2006, 08:24:52 PM »
If it's a tape stripe, a single-edge razor blade scraper works best.  If it's painted on, try the Easy-Off oven cleaner method, or you can get some fiberglass paint stripper.  Most of these are tape, which is pretty easy to get off with the scraper.
April 08, 2006, 08:56:42 PM
« Reply #4 on: April 08, 2006, 08:56:42 PM »
For the tape, a hair dryer helps soften the glue and makes the job a lot easier.  A heat gun will work of course but it is possible to damage the gelcoat or fiberglass with the heat gun.  A hair dryer doesn't get hot enough to hurt anything.
April 08, 2006, 11:31:19 PM
dusky
« Reply #5 on: April 08, 2006, 11:31:19 PM »
Thanks to all.  Will let you know how it works next week.
JR
North Shore, MA
April 13, 2006, 09:04:59 PM
dusky
« Reply #6 on: April 13, 2006, 09:04:59 PM »
No luck with razor blade or oven cleaner, sanded it down an will cover in primer.
North Shore, MA
