Author Topic: Input\opinions needed  (Read 490 times)
June 01, 2012, 09:19:53 AM
Read 490 times
xo4001
« on: June 01, 2012, 09:19:53 AM »
Hi guys, need some inputopinions
I have a aquasport seahunter under restoration that need engines
I have a bracket for it and wanted to put 2X 150Hp four strokes
Someone offer me a pair of 115 four strokes with 600 hrs.
I like the idea to save 200lbs less on the bracket
Any input pro and con is appreciated
Martin
1971? Aquasport 240 Seahunter
H254
2 X Merc 115 4s
June 01, 2012, 11:12:22 AM
Re: Input\opinions needed
« Reply #1 on: June 01, 2012, 11:12:22 AM »
Martin,
You'll be fine with the 115's on that hull if they have been maintained and the price is right. You'll save a little gas money too.You guys run mostly Yamaha's there, right?
BTW, on which island do you reside? Tx.
June 01, 2012, 02:50:16 PM
xo4001
« Reply #2 on: June 01, 2012, 02:50:16 PM »
Thanks Gran
The reason I looking at 2 is when 1 fails there is 1 to get me home
1 115 will get me on plane? It’s a heavy boat and I added some to!
Will add tabs when ready
Yes I safe some gas money if I run her on the economical speed
The Yamaha is very popular here but we see all kinds of outboards
I'm on Grand Bahama Freeport area
Anyone who has a opinion let me know please
H254
2 X Merc 115 4s
June 01, 2012, 03:17:42 PM
« Reply #3 on: June 01, 2012, 03:17:42 PM »
Examples:
Aquasport 250CCP, twin 115 Yamaha's, top speed 38mph, planed on one engine, ran 20 mph on one at 4600 rpm (numbers based on memory 25 years ago). Friend's boat.
Pursuit 2470, twin 130 Yamahas, top speed 38 mph, planed easily on one, 21 mph at 4600. This boat weighed 3250 lbs dry, hull only. My old boat.
You should be good, unless the boat is carrying a bunch of wet foam in the stringers/and/or saturated transom.
Just curious, what brand of engines are the 115's?
June 01, 2012, 05:14:57 PM
xo4001
« Reply #4 on: June 01, 2012, 05:14:57 PM »
I see your memory served you well
The transom is redone
And the foam is not wet in the stringers
The engines are Yamaha
I will take a very close look at them and go from there
H254
2 X Merc 115 4s
June 03, 2012, 05:35:54 PM
« Reply #5 on: June 03, 2012, 05:35:54 PM »
Martin - ditto on the twin 115s - that's a nice setup on that boat.  Remember, "back in the day" when your boat was built, the biggest outboard you could buy was the Mercury 135 or the Evinrude 125 (and that was crank HP, not prop shaft).  A lot of the Sea Hunters were sold with twin 115 Mercs or twin 85/115 Rudes.  That 115 Yammie you are looking at is at least 115 prop shaft HP.  It will take a little work to get her propped right, but once you nail down the right prop, you will be happy with the performance.
You are also right regarding weight - saving 200+ lbs on the transom is a good thing.   :thumleft:
June 04, 2012, 05:05:25 PM
xo4001
« Reply #6 on: June 04, 2012, 05:05:25 PM »
Quote from: "GoneFission"
Thanks Capt. John
Spoke with the people today and they will set it up to test and do a computer check reading
When all go's well I will buy them and then I have hurry up with the boat
Let you know how it go
H254
2 X Merc 115 4s
