Author Topic: Fuel milage for 225 Explorer with 200 Evinrude?  (Read 893 times)
May 30, 2012, 03:12:12 PM
Read 893 times
aquasport24
« on: May 30, 2012, 03:12:12 PM »
I have owned the boat for about a year.  Just wondering what some of you other owners of this boat and motor combo are getting fuel milage wise.
1996 Aquasport 225 Explorer with a 1996 200 Evinrude Ocean Pro (carbed)
I just put a fuel flow scan on the boat but have not been able to get the boat wet since April due to my new baby boy.
May 30, 2012, 04:09:45 PM
Re: Fuel milage for 225 Explorer with 200 Evinrude?
« Reply #1 on: May 30, 2012, 04:09:45 PM »
I have a 245 with a 225 Johnson so my burn will be higher.  I haven't had the boat long enough to wrok up an average fuel burn yet.  I can tell you I can get about a 28-30 mph cruise and be indicating 13-15 GPH on the flowscan.  I was surprised at how much the you can lower the fuel burn by a small throttle adjustment and trim tab adjustment without loosing speed.  That gauge will pay for itself in no time!
May 30, 2012, 10:08:11 PM
« Reply #2 on: May 30, 2012, 10:08:11 PM »
Quote from: "wingtime"
They are well worth the money!
A 200 hp will burn around 20 gph at wide open throttle.  The in-between usage depends on a ton of variables.
May 30, 2012, 11:58:56 PM
« Reply #3 on: May 30, 2012, 11:58:56 PM »
I have the same boat just a 97, i'm getting 13 gph at 4200, 29-30 mph, the sweet spot sofar.
May 31, 2012, 12:28:43 AM
aquasport24
« Reply #4 on: May 31, 2012, 12:28:43 AM »
Circle hook,
what type and size prop are you turning?
May 31, 2012, 12:36:53 PM
« Reply #5 on: May 31, 2012, 12:36:53 PM »
I'm have the stock OMC stainless that came with it 15x17
June 01, 2012, 08:06:32 AM
« Reply #6 on: June 01, 2012, 08:06:32 AM »
although my boat is smaller and much lighter
cruise:
3500 rpm, 29.9 mph, 11.2 gph, 2.63 mpg
at WOT, 5600 rpm, 51 mph, 24.9 gph, 2.04 mpg
my gph at WOT was pretty high, but i changed sparkplugs, wires, and fixed a sticking timing advance, i now burn about 22.5 gph at wot
