Props
prop size for 1988 170 with 98 yamaha 90hp 2 stroke
Topic: prop size for 1988 170 with 98 yamaha 90hp 2 stroke (Read 797 times)
May 26, 2012, 11:57:21 PM
Read 797 times
lasandoval129
May 26, 2012, 11:57:21 PM »
Anybody knows the right prop size for my 88 170 with a 1998 Yamaha 90hp 2 stroke? I want good top end...
May 29, 2012, 06:30:49 PM
akbridge
Re: prop size for 1988 170 with 98 yamaha 90hp 2 stroke
May 29, 2012, 06:30:49 PM »
A 17" pitch should work well. Try using factory Yamaha stuff. They make good all around props. Try to get your Rpms around 5200. This will generally get you the best all around hole shot with good top speed. You should see about 38 mph max with that setup.
September 20, 2013, 12:16:33 AM
floridamisser52
September 20, 2013, 12:16:33 AM »
I've got a 1998 175 with a 9o hp cross flow . Got a 17 pitch factory original running 5200 wot rpm @ about 33mph with 2guys and 1/2 tank of fuel. Good hole shot, good performance through all ranges. That's how the factory designed the boat.
September 20, 2013, 08:46:55 AM
September 20, 2013, 08:46:55 AM »
I believe I have a 17" pitch prop on my 170's 1998 90hp looper. I get about 37 mph at 5300 wot.
Props
