Author Topic: Resin Question  (Read 845 times)
May 23, 2012, 11:37:12 AM
Read 845 times
Restless
  • NorthEast
Resin Question
« on: May 23, 2012, 11:37:12 AM »
Are you using polyester or epoxy resin to rebuild your transoms?
I would assume that polyester resin would work perfectly fine on the stringers since that is the original material, but would be concerned about polyester delaminating from plywood cored transoms after a few years.
May 23, 2012, 11:50:56 AM
Re: Resin Question
« Reply #1 on: May 23, 2012, 11:50:56 AM »
It comes down to how are you going to refinish the transom when you are done.  You can not put gel coat on epoxy since it won't stick to it so you have to paint it.  Polyester resin does not have anywhere near the secondary bonding strength of epoxy (sticking to cured resin) but you can gel coat it.    Epoxy is much more expensive, but it's stronger and resists water better than poly.  If you use polyester make sure you get a good high quality resin that is FRESH.
May 23, 2012, 12:12:44 PM
Re: Resin Question
« Reply #2 on: May 23, 2012, 12:12:44 PM »
How about vinylester?
May 23, 2012, 01:18:27 PM
dbiscayne
Re: Resin Question
« Reply #3 on: May 23, 2012, 01:18:27 PM »
Vinylester is good stuff, also can be gel coated, and falls between polyester and epoxy in terms of adhesion.
Everything Wingtime said is true, except I haven't found epoxy to be much more expensive than polyester or vinylester.  Theres several local shops in south florida selling 1:1 and 1:2 epoxy for around $45/gallon, been using it for years with no issues.  Other advantages besides much better secondary bonds is the lack of smell from epoxy and a longer working time = less waste.
Quote
You'd be better off with vinylester or epoxy- when dealing with cured polyester resin you're best bet is to use epoxy, especially if you're not going to gel coat it.  If the layup was new and everything built wet on wet the poly is fine, cured poly is a different case.
May 23, 2012, 01:22:34 PM
Curious
Re: Resin Question
« Reply #4 on: May 23, 2012, 01:22:34 PM »
I poured my transom using Nida Core pourable transom compound.  Since the Nida Core material is polyester based I used polyester resin to do the finish glass work.
Dan
1978 22 Family Fisherman
1996 Yamaha 200 SW Series
May 23, 2012, 01:31:03 PM
Restless
  • NorthEast
Re: Resin Question
« Reply #5 on: May 23, 2012, 01:31:03 PM »
Quote from: "dbiscayne"
Good point. The secondary bonding strength of poly is not very good.
May 24, 2012, 06:49:44 PM
kraw2
Re: Resin Question
« Reply #6 on: May 24, 2012, 06:49:44 PM »
You wouldn't believe how many new boats are still using Polyester resin..!
May 24, 2012, 07:01:32 PM
Re: Resin Question
« Reply #7 on: May 24, 2012, 07:01:32 PM »
Quote from: "kraw2"
New is not a problem since you are dealing with all primary bonds if the hull is layed up correctly.  Quality boats should have at least a barrier coat of a higher quality blister resistant resin.
May 24, 2012, 08:18:54 PM
dirtwheelsfl
Re: Resin Question
« Reply #8 on: May 24, 2012, 08:18:54 PM »
I would AT LEAST bond the 2 pieces of wood together with epoxy. If you have your heart set on re-gelling, do the rest of the laminating with vinylester. Its possible with epoxy, but difficult to get good results (meaning adhesion).
