Author Topic: 2002 205 Osprey question  (Read 606 times)
May 23, 2012, 08:01:12 AM
Read 606 times
Jcop243
« on: May 23, 2012, 08:01:12 AM »
I just purchased a 2002 205 Osprey with a 200hp Johnson. The boat is great, but I have a few questions to repair something's that are not working.
1st.  The floor fish boxes. (answered on the forums) I found that the SPX macerator pump gets submerged in the bilge area where aquasport mounted it. Water intrusion ruins the pump
2nd Anchor Locker does not have a drain. Retaining water. Any ideas would be appreciated. I could probably drill a drain hole, but I'm not sure of the layout, so I don't screw it up
May 23, 2012, 09:00:07 AM
Re: 2002 205 Osprey question
« Reply #1 on: May 23, 2012, 09:00:07 AM »
The fishbox drains should be tee'd together, relocate the pump to a higher area, a new 1 1/2" hose from the drain tee to the pump will be needed.  The pump can pull that short of a distance.
As far as your anchor locker, most are drained in this manner.  Drill a 3/8" hole in the floor in the aft starboard corner of the locker, angling out through the hullside.  Cover the hole on the hull with a clamshell facing aft and pointed downward at about a 45 degree angle...
May 23, 2012, 09:18:00 AM
Jcop243
« Reply #2 on: May 23, 2012, 09:18:00 AM »
Are there any pictures on the anchor locker
May 23, 2012, 09:21:50 AM
« Reply #3 on: May 23, 2012, 09:21:50 AM »
Quote from: "Jcop243"
Not exactly the sexiest thing to take a pic of... :shock:
May 23, 2012, 10:30:27 AM
« Reply #4 on: May 23, 2012, 10:30:27 AM »
Did someone say pics?
Now here's the exact same thing that SB describes only different :scratch:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=148168
Read whole thread.
No this is not your model, not even an Aquasport.
Yes it is a pic of an anchor locker and the clam shell drain.
No it's on the port side and is forward not aft in the locker (see I told ya it was different).
Illustration is what the link is for.
If the site of splintered gel coat makes you queasy, this might not be for you but.....
You get the idea.
Hole aft drains locker overboard while clam shell drain limits water from entering while underway.
Neat, clean look and difficulty level runs parallel to your skills.
Oh, welcome aboard :salut:  and as always,
First one's free. :mrgreen:
