Aquasport Discussion
Rub Rail Cleaning
Topic: Rub Rail Cleaning (Read 633 times)
May 13, 2012, 05:08:53 PM
Read 633 times
Curious
Rub Rail Cleaning
May 13, 2012, 05:08:53 PM »
I've got a 1978 22 Family Fisherman with a black rub rail and white insert. The white insert is basically black with years of mildew and dirt. Should I try to clean it or just get a new insert? If you guy recommend cleaning it, what should I use? So far acetone is the only thing that will come close to touching it, but is kinda detrimental to my health. If you recommend replacement, where should I get it from?
Thanks, Dan
Dan
1996 Yamaha 200 SW Series
May 13, 2012, 07:16:09 PM
Capt. Bill
NorthEast
Re: Rub Rail Cleaning
May 13, 2012, 07:16:09 PM »
Try Mold Armor. You get it at the super market. Have never seen anything clean stains like it. Spary on and the stains melt away.
Capt. Bill
Amy Marie
215 Explorer
Member # 2155
May 15, 2012, 02:02:26 PM
Curious
May 15, 2012, 02:02:26 PM »
Mold Armour. Great, thanks for the tip! I'll let you know how it goes.
Dan
May 15, 2012, 02:13:25 PM
May 15, 2012, 02:13:25 PM »
Try this... also, awesome stuff
http://www.clorox.com/products/clorox-clean-up-cleaner/
May 15, 2012, 03:39:23 PM
May 15, 2012, 03:39:23 PM »
If none of those work you can always wetsand it like I did mine. I tried a lot of different products and nothing would touch it. I started with 150 grit and then went to 320 and finished it off with 600 grit. At the same time I was diong the insert i was also sanding the rail itself because it was really bad as well.
If you don't want to do the black part i would run some duct tape on each edge to protect the black as when you sand a colored area when it dries it will have a white cast to it. This might sound like a lot of work but the last 2 grits go really fast as you are just sanding off the previous grits scratches. In other words take more time with the first grit and the ones that follow will be easy.
May 15, 2012, 08:06:59 PM
Curious
May 15, 2012, 08:06:59 PM »
Cripes, I never thought of that, and I think I have some kicking around somewhere. Thanks.
Dan
May 15, 2012, 08:08:16 PM
Curious
May 15, 2012, 08:08:16 PM »
You know what I'm honestly thinking of doing? Just getting some of the insert in black and replacing the white with black.
Dan
May 16, 2012, 09:34:02 AM
CTsalt12
May 16, 2012, 09:34:02 AM »
Scotch Brite Pads did the trick with about 90% of my rub rail insert. Matter of fact, scotch brite pads take care of almost all tough cleaning tasks on my boat
Jimbo
1989 175 Osprey
Rub Rail Cleaning
