Author Topic: 1974 19-6 Aquasport Rebuild  (Read 2302 times)
May 12, 2012, 09:02:35 PM
Read 2302 times
melba toast
« on: May 12, 2012, 09:02:35 PM »
Here is my Mike's personal boat. He is working on it on next to the proline. He got everything out today. We lifted the cap off and took out the console, front deck, and floor. Whoever had it before had done some work on the floor and foamed in some interesting artifacts.
Mike's Boat
Check out the green rubrail
Rubrail Gone!
Console Removed, Busy day at Fiber-plastics
Cap removed
About to remove the front deck
Front Deck Removed
Subfloor work done in the past by previous owner(s)
Previous foam work, inflated rubber gloves and overnight shipping boxes foamed in!
A 20' Dolphin Mike and Perry re-did 20 years ago, all in composite. Still Rock solid.
Inside of the Dolphin...
May 12, 2012, 11:15:16 PM
Re: 1974 196 Aquasport Rebuild
« Reply #1 on: May 12, 2012, 11:15:16 PM »
Excellent!!
That mystery stuff was cheap filler in 1992 :shock:
Save that army-man green rubrail. It may be worth a thousand dollars per foot on E-Bay in a few years :lol:
All kidding aside...thanks for joining, and glad you're here :thumright:
You're getting a clean job. Most of the Proline stringer rebuilds thus far have utilized the glass-wrapped grid system.
May 13, 2012, 08:03:24 AM
« Reply #2 on: May 13, 2012, 08:03:24 AM »
I think this one is a 19-6.
Side by side rebuilds, I don't think I have seen that one before!
May 18, 2012, 05:06:23 PM
melba toast
Re: 1974 19-6 Aquasport Rebuild
« Reply #3 on: May 18, 2012, 05:06:23 PM »
The transom work has already started on the 19-6 also. We plan on doing the 19-6 transom and the proline at the same time. Doing the rebuilds at the same time have both of us inspired to work a little faster. Everytime one of us gets a step done, the other wants to catch up!
May 18, 2012, 09:56:38 PM
« Reply #4 on: May 18, 2012, 09:56:38 PM »
Quote from: "melba toast"
Is that the "Dolphin" that was built just outside Homestead (Princeton) Fla. ?
If so, they always advertised "No wood, no rot". :scratch:
It sure looks like that builder's boat.
Just curious.
EDIT: Is this the same builder? http://www.dolphinboats.com/bayboat_20.php
May 20, 2012, 08:16:43 PM
melba toast
dolphin
« Reply #5 on: May 20, 2012, 08:16:43 PM »
It is a 1978 Dolphin. The stringers were foam filled, and had old wet foam. The something busted loose around the fuel tank, the hull split and the boat sank. Mike towed it in, fixed it, and then bought it from the guy. They later went back in and reglassed the stringers and beefed them up. They re-foamed it with modern foam and cut the liner out, then added a new floor.
May 20, 2012, 08:18:05 PM
melba toast
transom prep complete
« Reply #6 on: May 20, 2012, 08:18:05 PM »
19-6 transom ready for glass and coosa
May 21, 2012, 05:46:23 AM
MarshMarlowe196
« Reply #7 on: May 21, 2012, 05:46:23 AM »
Looks like you guys are moving right along.  I look forward to following this thread
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
May 21, 2012, 08:21:47 AM
Re: dolphin
« Reply #8 on: May 21, 2012, 08:21:47 AM »
Wow.
That's very interesting.  :o
Keep the photos coming on the rebuild. :thumleft:
May 26, 2012, 04:34:27 PM
melba toast
Vents sealed
« Reply #9 on: May 26, 2012, 04:34:27 PM »
After prepping the transom, Mike is pondering going in a different direction. He may extend this hull 18". We measured today and its very possible despite the taper. Stay tuned. In the meantime...
Vents patched
Outside view
