Believe what the CCP owners are saying...if it ain't broke, don't fix it. Don't get too far ahead with the demolition....ten cents worth of demolition now equates to a minimum of hundreds, maybe thousands later.The CCP stringers are big and beefy. Unless they are heavily pierced from above....foam saturation on these boats is not/never has been an issue as with the twelve degree hulls. Heavier glass, screws in different places, etc.....Not to say they can't break tabs in a heavy seaway. That usually occurs near the stern.Do careful exploration. The foam saturation experiences you have read here are not in general applicable to your hull.
