Author Topic: Radio questions(VHF and AM/FM)  (Read 474 times)
May 04, 2012, 09:43:24 AM
Read 474 times
gman 82 aquasport
« on: May 04, 2012, 09:43:24 AM »
Putting my boat back together and installing my electronics in my overhead box on my T-Top..Question is this...I have a VHF radio(West Marine) that is hooked to my GPS(Garmin), they sit side by side about 2 inches apart in the box, I have the VHF mounted on the ceiling of the box, leaves an open space under it... Would it cause interference to mount my AM/FM stereo under it in the box, I have room on the other side of the GPS to mount it but was looking to save that room for  maps, handheld gps, phones, etc..Thanks for any info.....I will be mounting the stuff this weekend.. :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
May 04, 2012, 09:49:14 AM
Re: Radio questions(VHF and AM/FM)
« Reply #1 on: May 04, 2012, 09:49:14 AM »
Most are shielded, but check with the manufacturer and they will be able to tell you. I would worry more about the heat coming from the stereo and cooking the VHF.
May 04, 2012, 12:06:02 PM
« Reply #2 on: May 04, 2012, 12:06:02 PM »
You will be fine as long as you have an inch or so between them for air circulation.
As a side note, don't be tempted with one of those splitter things that combine the VHF and AM/FM on the same antenna.  Those things compromise the performance of both units.
May 04, 2012, 12:17:28 PM
« Reply #3 on: May 04, 2012, 12:17:28 PM »
What JJ said...
May 04, 2012, 04:27:51 PM
« Reply #4 on: May 04, 2012, 04:27:51 PM »
yeah I found one of those splitter units on my 245 and I promptly deep sixxed that sucker.
May 05, 2012, 04:49:38 PM
gman 82 aquasport
« Reply #5 on: May 05, 2012, 04:49:38 PM »
Decided to put the radio at the other side of the box, i am using separate antennas for each....thanks for the info.. :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
