Author Topic: 170 & Jack Plate  (Read 688 times)
April 29, 2012, 09:24:20 PM
Read 688 times
pbustle
170 & Jack Plate
« on: April 29, 2012, 09:24:20 PM »
Need some help from those of you that own a 170 equiped with a Jack Plate.   I installed a Bobs jack plate and when i put the boat in reverse, I was really suprised at how much water flows up through the jack plate and into the boat.  I thought it was bad before when i put the boat in reverse.  Its fine at Idle, but any extra throttle and in comes the water.  Any suggestions and has anyone else found this to be a problem?  Any Ideas on how to stop/prevent or slow this down?
Pat Bustle
Yacht & Ship Broker
United Yacht sales
http://www.unitedyacht.com/pbustle
pbustle@unitedyacht.com
1988 170 Aquasport - 1996 130HP Evinrude
1974 19-6 Aquasport - Upside down \":-|\"
1982 50\' Hatteras Convertible
April 29, 2012, 09:44:55 PM
Capt Matt
Re: 170 & Jack Plate
« Reply #1 on: April 29, 2012, 09:44:55 PM »
Every low transom boat I have ran with a jack plate does the same thing, seems to funnel the water between the transom and the jack plate. Don't really know of a easy fix though
Capt Matt
Light tackle sportfishing
April 29, 2012, 11:46:56 PM
pbustle
« Reply #2 on: April 29, 2012, 11:46:56 PM »
I didn't say the fix has to be easy, but I was thinking about cutting out a piece of starboard in the shape of the bottom of the Jack Plate.  Then mounting it to the bottom. Hopefully it would stop/slow the flow of water in the upward direction.  Anyone ever tried this?  I figure even if it does not stop the water completly and it slows it down, it shoudl be helpful.  I have run a great deal of boats with jack plates and never had this much water coming in while in reverse.
I will say however, the boat performs a great deal better with the jack plate installed.
Pat Bustle
Yacht & Ship Broker
United Yacht sales
April 30, 2012, 05:23:57 AM
« Reply #3 on: April 30, 2012, 05:23:57 AM »
What does Bob's Machine Shop say - I'm sure they've been asked that a ton.
April 30, 2012, 08:41:01 PM
akbridge
« Reply #4 on: April 30, 2012, 08:41:01 PM »
I have the same issue with my 170.  I thought about using some rubber blanket material to prevent water from coming up.  But I got lazy and figured out hat if I trimmed up some the water from the prop goes under the boat rather than in.  The starboard could help.  I find I get more water into the boat from backing into the wind and splashing than up through the plate.
May 01, 2012, 06:08:53 AM
HIFLUTIN
« Reply #5 on: May 01, 2012, 06:08:53 AM »
Call Bobs-They use to be great to work with, The ole man Bob was very "hands on" not sure if he is still there. Post what they say gettin ready to put one on mine
May 01, 2012, 10:19:33 AM
Capt Matt
« Reply #6 on: May 01, 2012, 10:19:33 AM »
Maybe a splash board across the transom or a thin aluminum plate under the jack plate should help
Capt Matt
