Author Topic: Checking gear case lubricant level  (Read 1214 times)
April 25, 2012, 07:55:23 PM
Read 1214 times
foreverstrung
« on: April 25, 2012, 07:55:23 PM »
So I had the boat out on the trailer last week to install trim tabs and general maintenance. The only issue I had was checking the gear case lubricant level. I couldn't get the vent screw loose to check the level. I was worried about stripping the screw head. Tried gently tapping the screw driver as I turned the screwdriver, but no go.
Suggestions? Should I just empty it all out and re-fill? If so, how do I determine the correct level/
2000 Aquasport 215 Explorer/Mercury 200, carb 2 stroke
April 25, 2012, 08:07:06 PM
Re: Checking gear case lubricant level
« Reply #1 on: April 25, 2012, 08:07:06 PM »
You will have to get the top one out anyway as that is how you determine fill level. You fill from the bottom screw and stop when oil comes out the top hole. Get a hand pump to make it an easy job.
April 25, 2012, 08:16:47 PM
foreverstrung
« Reply #2 on: April 25, 2012, 08:16:47 PM »
I figured as much, but how the heck do I get that screw out. Just a big flat head and just lean into it?
April 25, 2012, 08:20:42 PM
dburr
« Reply #3 on: April 25, 2012, 08:20:42 PM »
BIG square shank and an adjustable wrench and lean on it like your life depends on it... Make sure the screw driver does not move in the slot and is as wide as the slot....
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
April 25, 2012, 08:28:09 PM
dburr
« Reply #4 on: April 25, 2012, 08:28:09 PM »
I took a short length of plastic tubing, like 3/16 size and put it on the fill nozzle of the oil jug then cramed it in the lower unit fill hole.  Then took a soccer ball needle that just happens to fit in my air chuck and jammed it in the neck of the jug and flipped it upside down,and shot a little air into the jug.. Fastest oil fill ever.  And the hole in the neck kept the oil from spilling all over the place when I put the jug down.  My short term memory is gone...
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
April 25, 2012, 08:29:04 PM
« Reply #5 on: April 25, 2012, 08:29:04 PM »
PB Blaster or liquid wrench. Let it sit for 24 hours. X2 on the right size screwdriver. Tap on the end of the screwdriver lightly! I used to sell an attachment for a air hammer that would fit a phillips or flat. I need to find that thing. It worked really well for stuff like this. Sold it guys restoring cars to loosen rusted screws.
April 25, 2012, 08:37:28 PM
« Reply #6 on: April 25, 2012, 08:37:28 PM »
When you are filling it with the hand pump and the fluid starts to come out the top, walk away from it for ten minutes or so and let the fluid settle.  When you come back to it, pump a little more fluid into it to top it off.
April 26, 2012, 06:50:41 AM
« Reply #7 on: April 26, 2012, 06:50:41 AM »
This will usually do the trick for the stubborn ones, tilt the engine all the way up so your not working on the ground, get it seated well, pressure in the CCW direction, and one nice tap, she'll come out, don't forget a new fiber gasket for the two plugs before reinstall.
http://www.harborfreight.com/impact-scr ... 37530.html
April 26, 2012, 09:11:29 AM
« Reply #8 on: April 26, 2012, 09:11:29 AM »
Yup Marc is right...  no tool box should be without an impact driver.  Those things have saved my butt many times.
I have a large screwdriver that has a hex drive area just below the handle.  I use that by really pushing hard on it while I turn it with a wrench.  Make sure the screwdriver head fits the slot of the screw.  Too small of a head and you are sure to bum up the plug.
April 26, 2012, 09:30:21 AM
« Reply #9 on: April 26, 2012, 09:30:21 AM »
Marc's impact driver is the way to go but...
What's with this "light" hammer tap stuff?  Get a big azz screwdriver that fits the screw slot perfectly and whack the heck out of it one time with a big hammer.  That's usually all it takes.
Oh yeah, if you use an impact driver, make sure it's set to unscrew and not tighten it more.  Some only go one way but other brands are reversible.
April 26, 2012, 10:09:06 AM
« Reply #10 on: April 26, 2012, 10:09:06 AM »
Quote from: "John Jones"
In my education through the school of Lessons Learned, and when dealing with marine stuff, I usually begin with the least power required to accomplish the task, then increase expotentially as the frustration level rises, usually ending in blood letting and destruction of the part, then Level II begins.  Working with my neighbor last night with his 4.3 I/O and the oil drain plug is completely rusted away, may have to pull the engine to replace the entire pan. :thumbdown:
April 26, 2012, 10:30:24 AM
« Reply #11 on: April 26, 2012, 10:30:24 AM »
So is the oil pan rusted out and leaking?  Or are you just trying to change the oil?  And if your changing the oil don't you usually just pump it out?
April 26, 2012, 08:23:35 PM
April 26, 2012, 11:25:06 PM
« Reply #13 on: April 26, 2012, 11:25:06 PM »
 :lol: Well said. :thumright:
May 01, 2012, 01:20:21 PM
TheKid
« Reply #14 on: May 01, 2012, 01:20:21 PM »
Quote from: "Blue Agave"
Or just pump till the bubbles stop.
Lower units usually take less then a quart. So pumping from a quart should allow for overflow till bubbles stop.
A million ways to skin a cat!
For the vent...all great ideas. Best is having the perfect screw driver for the screw. Thick slot, large diameter handle for max torque and only as long as necessary to prevent any wobble.
Replacing the gasket every time also prevents this sticky stuff from happening in the first place.
I also have an impact driver. Great tool when needed. However I have found that it is difficult to use in this application. Unless the lower unit is supported from the other side most of the force goes into moving the entire motor.
Perhaps that's just me.
