Author Topic: '72 196 with a 115 yamaha 4 stroke. What prop?  (Read 447 times)
April 25, 2012, 04:59:57 PM
Read 447 times
tmyers
« on: April 25, 2012, 04:59:57 PM »
I am seeing a lot of 17 on the 196 for 115 2 strokes.  Is anyone running a 4 stroke with a different prop?
May 02, 2012, 03:44:45 PM
Dhadley
Re: '72 196 with a 115 yamaha 4 stroke. What prop?
« Reply #1 on: May 02, 2012, 03:44:45 PM »
You'll likely run the same thing. There's a difference in some 4 strokes vs 2 stroks as far as gear ratio so that will compensate for any lack of bottom end power. Make sure to set that 4 stroke up to as close to 6000 as you can so the holeshot won't suffer.
